EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   How dirty is a CONSTANT RPM 2-stroke with a Tune-Pipe? (https://ecomodder.com/forum/showthread.php/how-dirty-constant-rpm-2-stroke-tune-pipe-41585.html)
Logic 10-27-2024 02:41 PM
I was thinking about light and simple so 2 stroke came up.
If the intake charge is escaping out the exhaust
except
when the tuned expansion pipe is kicking it 'all' back; how efficient would a constant and exact/optimal RPM, 2-stoke engine, turning a genset, be?
(We aren't discussing generator/alternator efficiency here)
Here's a nice read on the why and how of Tune-Pipes and some dyno graphs:
http://www.jawamania.info/Files/tech...ust_system.pdf
Here's emissions numbers of various engines doing the Euro Cycle. etc:
https://publications.jrc.ec.europa.e...%20%282%29.pdf
But no constant rpm with tuned expansion pipe research I could find yet. :(
Or
How efficient and clean is a 2-stroke with a variable Tune-Pipe?
Here's a study on a variable Tune-Pipe:
Improving the Performance of Two-stroke Motorcycle with
Tuned Adjustable Exhaust Pipe
https://maxwellsci.com/print/rjaset/(2)59-65.pdf
The tuned exhaust system was found to improve fuel economy of the engine by 12%.
The major engine-out emissions, HC and CO were reduced by a minimum of 27.8% and 10.7% respectively.
An improved power output of 15.8% increase was achieved.
As a bonus, it w as also found that the exhaust noise was reduced .
https://www.youtube.com/watch?v=0odVzSgufjk
https://www.tiktok.com/@europeanpowe...60752034729248
I'll do more research on this but if you have a moment to look at the graphs etc in the linked study, I would like the opinions of those who are more up to speed with the numbers in eco 4-strokes for HC, CO, etc plz so we can compare.
Many of the papers also speak of cleaning up the exhaust.
I also have some ideas on cleaning up the exhaust. :)
freebeard 10-27-2024 03:09 PM
Not the expert your looking for; but wouldn't the tune-pipe reduce exhaust gas [effectively] recirculation? Which comes on all new motors?
The percentages you report are impressive.
Logic 10-28-2024 05:15 AM
Potential of Expansion Chamber Exhaust Pipes for Two-Stroke Powered Tools
by Porsche Engineering Services
"...using expansion chambers, power of the series production engine can be raised by 40 percent while still offering an advantage in emissions of 34 percent.
Tuning an expansion chamber for the same peak horsepower as the box silencer gives an advantage in emissions by 62 percent..."
https://sci-hub.ru/10.4271/2010-32-0011
No it wouldn't. See this animation:
https://www.youtube.com/watch?v=HbqS3fz8EDA
At the optimal rpm the Tune-Pipe is just making it so 'all' the escaped air/fuel mixture is forced back into the cylinder just before the exhaust port closes.
That's what negates the BIG negative of the 2-Stroke.
Also NB that with a small reed valve to intake a bit of plain air into the transfer port above; the 1st bit of air would not contain any fuel and thus not waste/pollute as much.
If you wanted to do EGR, you would do it after the Tune-Pipe on that last bit of pipe where the muffler is placed.
You also want a very fast burn so that it's all done before the exhaust port opens.
The extra (very turbulent) time the charge spends below the piston likely helps tremendously, but 2-strokes do seem to benefit from hydrogen addition more than 4-strokes do.
I'm NOT saying you get more energy out than you put in, just that it helps with emissions.
https://www.sciencedirect.com/scienc...05844024026288
cRiPpLe_rOoStEr 10-30-2024 12:56 AM
I have never seen any 2-stroke engine with EGR. But anyway, maybe picking the EGR flow further down the exhaust stream might lead to some natural cooling prior to the exhaust gasses being recirculated, which might be good.
Logic 11-05-2024 12:11 PM
Yes very good. The colder the better, for timing advance / power.
For economy..?
But most all EGR systems have a cooler that might be skipped with enough open air EGR plumbing as would be the case on a motorbike or under a car.
aerohead 11-07-2024 11:02 AM
' two-stroke engines '
Two-stroke engines were banned in the United States, starting around 1991.
Orbital Engine's 2-stroke, of much interest in the automotive industry, was finally abandoned, after unsuccessful attempts to bring them into compliance for tailpipe emissions.
Today, in the United States, the only 2-strokes allowed to be sold, are under 50cc in displacement, and mostly for powered yard-care products and chainsaws.
They're 'filthy' and will be superannuated by electric replacements.
Logic 11-10-2024 06:16 AM
I'm going to pretend we actually read each others posts with the intent to understand,
rather than immediately rushing to engage in some insane game of intellectual one-upmanship to satisfy a need to be considered cleverest and for the pure joy of a good argument.
ie: This reply is not actually for aerohead, as he wont read it with the intent to understand it, but for others reading this thread.
Whether they are banned in the USA or not is NOT the question.
The question is:
How clean can you make a 2-stroke
IF
it runs at a constant rpm..?
(as is the case in a serial hybrid)
So if a 2-stroke is run at a constant rpm we can get most of the charge that is otherwise lost out the exhaust to return to the combustion chamber, with a Tune-Pipe.
But not all as there will be some dilution in the tune pipe.
If a tiny reed valve is added to the TRANSFER port;
then the first bit of lost to exhaust charge is not in fact charge but air.
The first bit to be lost is the last bit to be returned by the tune pipe.
So any dilution in the tune pipe is more with plain air than charge.
Meaning more to all charge is returned to the cylinder, by the tune-pipe before the exhaust port closes.
ie: in the video that 1st bit of green to escape, which is the last bit of green to be returned is plain air and any dilution is no longer a problem.
The other place where there is a problem is with the power stroke only being around half a downward stroke, vs a 4-stroke's full stroke, before the exhaust port opens.
This means that there is way less time for a complete and clean burn of all the charge.
If one were to add hydrogen; the burn is speeded up dramatically, making that initial exhaust escaping down the pipe cleaner.
Here some sort of onboard hydrogen or HHO/Hydroxy cell could be used.
NOT for economy, but for improved emissions...
( Do NB MIT etc's plasmatrons that are in fact efficient at onboard hydrogen production however)
That leaves the lubricating oil and soot as an issue.
They are MUCH heavier than the gasses in the exhaust.
So a centrifuge after the tune-pipe would be efficient at separating these particulates in the exhaust from the gasses, whence they could be returned to the intake.
( I suspect a centrifuge may also be a very effective muffler. Especially with some thought in that direction put into it's design.
I also NB the effectiveness of Helmholtz and /or Quarter Wave Resonators on fixed rpm exhaust etc noise )
The last step, if still required after adding hydrogen, would be an exhaust catalyst.
They need the high temperature one sees in the exhaust just after the engine, to work.
So they would have to be before the tune-pipe.
That simply doesn't work.
Leaving the placement of the catalyst after the tune-pipe and centrifuge as the last remaining problem to be solved before light and simple, fixed rpm 2-strokes might be unbanned.
Any ideas?
One does not want to waste fuel to re heat a damn catalyst..?
cRiPpLe_rOoStEr 11-17-2024 11:06 PM
Aren't direct-injection outboard motors and snowmobiles still allowed there? And what about some motorcycles fitted with that transfer port injection (TPI) used by KTM and Husqvarna?
Logic 02-23-2025 04:33 PM
Clean at any rpm by injecting fuel directly into the cylinder AFTER the exhaust port is closed:
Aprilia's direct injection two-stroke engine concept
https://www.cycleworld.com/resizer/U...5JN7RELZYA.jpg
There a shaft driven air compressor involved and a lot of complexity.
Compare that to the simplicity and cost of Constant rpm 2-stroke.
cRiPpLe_rOoStEr 02-26-2025 11:50 PM
That TPI system used by KTM and Husqvarna is not the same as direct injection, as the fuel is injected through the transfer ports instead of through the cylinder head. AFAIK the TPI doesn't rely on the compressor to provide a spray-guided injection similar to what Orbital Engines developed (and which seems to be what Aprilia was trying).
Andyman 03-18-2025 08:58 AM
Any ideas?
I'm not sure that Aerohead disapproved of this subject. I think his point was that the legal requirements could be difficult to satisfy for new two stroke engine products in the US. I thought that the information he gave us was useful. If a new two stoke engine could meet the emission requirements it may be accepted. With the recent changes at the EPA, that might be easier. I hope we are not going to be breathing more pollution soon, but we probably will because of the large amount of fuel being used or burned up in wars. If we can clean up old two stroke engines, it would be a step in the right direction.
I do have an idea. I suggest wrapping the expansion chamber (tune-pipe) in insulation so the exhaust gas will be hot enough for the catalyst. The centrifuge may not be needed if the two stroke oil burns cleanly. I think it would be useful to add valves to the transfer and exhaust ports. They could be rotory valves so they can operate quickly. That could improve engine efficiency by delaying the opening of the exhaust port. The transfer port opening could also be delayed until after the piston reaches the bottom of the stroke to allow enough time for most of the exhaust to leave the cylinder before the new fuel mixture starts to go in. This might work better if a reed valve is added to the bottom of the transfer port and the volume of the transfer port is increased.
Logic 03-18-2025 10:09 AM
Originally Posted by Andyman (Post 699374)
I'm not sure that Aerohead disapproved of this subject. I think his point was that the legal requirements could be difficult to satisfy for new two stroke engine products in the US. I thought that the information he gave us was useful. If a new two stoke engine could meet the emission requirements it may be accepted. With the recent changes at the EPA, that might be easier. I hope we are not going to be breathing more pollution soon. If we can clean up old two stroke engines, it would be a step in the right direction.
People make the mistake of liking to think that electricity, EVs and even 4-Strokes are clean Andyman. They are not:
https://upload.wikimedia.org/wikiped...gy_mix.svg.png
https://en.wikipedia.org/wiki/World_...nd_consumption
Wind blows.
We all of us, anywhere, breath in an air molecule that's been in for eg: Marilyn Monroe's lungs, once every 30 years IIRC.
And she exhaled what? A millionth of what a car or power plant does in a day!?
Then consider that city driving, which is 98% of all driving worldwide means accelerating WEIGHT from robot to robot etc, and that, that accounts for 68% of fuel used!
(vs 14% for aero)
So ye; the lighter we can make vehicles...
and 2-strokes win here, as far as available engines go.
(Better would be Linear Generators, but that's not going anywhere fast atm)
The other thing to consider is that this clean 2-stroke is a ~250cc CONSTANT rpm engine to replace the average load of around 20kw of a normal, variable rpm engine, in a series hybrid.
This lowers the expensive, weighty battery requirements dramatically and makes optimizing the engine (of any sort) far-far cheaper and simpler.
ie: There is no need for fancy, expensive valves and direct injection etc, that clean up the emissions from a variable rpm engine:
The ports (and tune pipe etc) can all be optimized to open at the optimal/desired crank angle/rpm... easily and cheaply!
I LIKE the wrapped tune pipe idea though! Thx! :)
If it's designed fort the extra volume; that's good thinking (of a simple solution!) and can be extended to any centrifuge too, for very little in extra weight.
cRiPpLe_rOoStEr 03-20-2025 01:10 AM
In fact it is possible to make an emissions-compliant 2-stroke engine, yet it would be harder to justify from a marketing standpoint after some countries effectively banned the imports of new 2-stroke motorcycles around 2008, and some of those countries in fact have a larger motorcycle market than the United States. Not to mention the latest successful 2-stroke engines became more concentrated around lower displacement brackets.
