Old 04-21-2010, 12:04 AM   #1 (permalink)
ive got RPM problems
Ive got a '95 Ford Probe 5 speed. its a 2.5L V6. when im doing 100 km/h = 60 mph my car is reving at 3000 RPMs, in 5th gear. is there any way to lower my RPMs? Could this be hurtin my engine or tranny?
Old 04-21-2010, 09:47 AM   #2 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
Im not sure which trans your V6 has but I know the G-series mazda trans has several 5th gears available. I swapped a .71 5th from a Mazda 626 in place of my .8 5th in my Mercury Capri trans (G25MR). It dropped the rpms at 60 about 300-400. Cruises 60 at about 2500 now.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
The Following User Says Thank You to bhazard For This Useful Post:
minihoff16 (04-25-2010)
Old 04-21-2010, 05:12 PM   #3 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Larger diameter tires will change your final drive ratio. the only problem is that it changes them all, so slower acceleration could be a downside.
The Following User Says Thank You to wyatt For This Useful Post:
100 km/h, 2.5l, 5th, highway, rpms
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Ethanol problems ? Denis DIY / How-to 16 05-31-2011 05:14 PM
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Lower RPM for higher MPG? UltraJosua EcoModding Central 7 07-17-2009 01:56 PM
2000 rpm taco General Efficiency Discussion 37 02-28-2009 05:11 PM
