How many MPG are you getting at 70 mph (GPS)
Just a poll to see where everyone is at!
Also to add oem speedo's read 2% fast. So if you're going off an accurate oem speedo 71.4 displayed = 70 actual Comment what vehicle sub trim and what ambient temp for your vehicle. |
Prius 70F 70 mph ~ 46 mpg
Translate to ton-miles. That, at least, provides context.
Payload expressed as tons (percentage thereof) X fuel burn 1,280-lbs payload my pickup with driver X 20-mpg (@70) = 10 ton/miles per gallon. 150-lb EM’er X 45-mpg (@70) = 3.3 ton/miles per gallon. When I hitch the trailer (8k), it shoots to over 60 with four passengers also present. Four persons uncomfortably aboard an air-conditioned go kart hits a staggering 21 T/M gallon. Loserville is a town of single person vehicles. Fuel burn or fuel type just doesn’t matter. . . |
* 40mpg plus vehicles are the focus
I dunno! I only drive 70 mph a few times a year, when on long (multi-day) trips.
The rest of the year, I toodle along the scenic side roads at ~50 mph / 80 km/h. But theoretically, an unmodified 5-speed Mirage is good for ~42 MPG US @ 70 mph on level ground in warm weather. The Metro/Firefly (unmodified) is about the same. |
I recently broke 50mpg at 70 in my Acura TSX swapped Insight on a longer trip. It's hard to know if there wasn't some external factor like a tail wind. MPG at that speed seems pretty variable, I've seen as low as 46, but road conditions in winter are highly variable. I'm willing to bet 50+ in summer will be normal. Could probably break 60+ with P&G.
My other (stock) Insight easily maintains 65-70mpg in winter at 70mph. |
I’m not even on your chart but I still enjoy and try to contribute to this site. Been here a long time, I do not own a Metro any longer.
Hmmmm... when was the last time I went 70? On the motorcycle I think.
Amateurs.
I get around 120mpg at 70mph in the summer in the leaf. To be a little more fair my wife's hybrid sonata gets around 40mpg, during the summer at 70mph. |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
