EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   How-To: Metro Kammback with Window! (https://ecomodder.com/forum/showthread.php/how-metro-kammback-window-18142.html)
Geo Metropolis 07-13-2011 04:21 AM
First I must thank metroMPG for his inspiring innovation, measurements and suggestions, they were invaluable in making this happen. My goal was simply to mimic the shape and size of his kammback but construct it more simply with aluminum and coreplast and the addition of a plexiglass window for improved rear view.
Here are the tools/supplies needed:
http://i833.photobucket.com/albums/z...707_181758.jpg
  • Aluminum bar stock or strips. (I cut up an aluminum construction sign I purchased at a scrap yard)
  • Self Tapping Screws
  • Tinsnips (these worked amazingly well for aluminum trimming/cutting)
  • Drill with drill bits and screwdriver bits
  • permanent marker
  • Metal Punch (optional but helpful)
  • two sets of pliers (for bending the aluminum)
  • Rivets/Rivet tool (optional - I ended up not using it)
  • Coreplast
  • plexiglass
  • Boxcutter or razorknife
  • Tape for sealing/smoothing edges
  • Time - about 5 hours
STEP 1: Using the self-tapping screws attach two equal lengths of aluminum to the hatch above the window (Yes I drilled into the car) right around the width of the drip rails. Bend them roughly to a 15% angle from the roof and be sure your bend is about 1/4 inch short of the actual roofline (so the coreplast will sit flush when attached on top. I recommend you 1) use both sets of pliers to grab and bend the aluminum precisely where you intend to, and 2) hold the aluminum in place and use the metalpunch to mark the spots you want to install the screws. Step 1 should look something like this:
http://i833.photobucket.com/albums/z...709_131504.jpg
Step 2: cut a strip of aluminum to be roughly the same length as the distance between drip rails and - using the self tapping screws (even if you plan on riveting later - because you'll be adding lots more layers to these drill points) - attach the ends to the ends of your first two pieces so that you have something like this:
http://i833.photobucket.com/albums/z...707_190018.jpg
Step 3: Build the bottom outside braces. For these I chose to screw into the hatch again, this time between the taillights and the hatch window. Bend them so they will make a correct angle toward the ends of your trailing cross piece (again leave about 1/4 of an inch to accommodate the coreplast you'll be adding). Ensure you have the correct angle then using the pliers bend the end not attached to the car so that it will hold up the rear corner of the kammback. The angle will be funky and leave some extra aluminum sticking out, mark it with the marker and trim it with the tinsnips. Do this on both sides and then screw the braces in using your existing self-tappers. Should look something like this (except hopefully you're working in the day):
http://i833.photobucket.com/albums/z...708_001041.jpg
Step 4: I fitted a plexiglass scrap I picked up at the plastics place to ride across the top of the kammback overlapping the aluminum all the way to the trailing edge. I then tied in one more crossmember of aluminum to act as a support for the leading edge of this window. I suggest you lay it in place then screw it on then mark and trim it. I originally made it match the length of the trailing crossmember but it need up kinda closing the width of the whole thing so I undid those screws and redrilled. You can see the crossbrace here:
http://i833.photobucket.com/albums/z...709_125441.jpg
Step 5: Step back to admire your skeleton and compare it with MetroMPG's (his was tuft-tested and adjusted to near perfection). At this point I began to get excited:
http://i833.photobucket.com/albums/z...709_085218.jpg
Step 6: Cut a generous piece of coreplast to the rough shape of the roofline, width of the kammback top, so that it extends down over top frame of the window. Should look something like:
http://i833.photobucket.com/albums/z...709_132829.jpg
Step 7:One at a time pull the screws that make up the kamm-window frame, carefully mark and drill through the plexiglass and install it over the top of the frame. Be really careful to pre-drill, I recommend you do not use self tappers until you've predrilled and definitely don't use the metalpunch to mark your drill spot. Once this is done, begin securing the coreplast to the plexi, to the aluminum. You can see that here:
http://i833.photobucket.com/albums/z...709_132043.jpg
This was feeling a little flimsy in the middle so I added another brace at the top of the hatch. It looks like this:
Once everything is in place trim the coreplast top layer along the side edges of the kammback top so that it can be bent down.
Step 8: Hold a piece of coreplast along one side of the kammback and trace a marker around things to make a good template for the side. Cut it like so:
http://i833.photobucket.com/albums/z...709_141013.jpg
Step 9 Trim the top layer of the coreplast side pieces along the side edges of the kammback top so that it can be bent to and attached from the top. Should look something like this:
http://i833.photobucket.com/albums/z...709_141739.jpg
Tep10: Attach coreplast with a generous amount of screws and figure out how you'll trim/overlap the extra bits like so:
from this...http://i833.photobucket.com/albums/z...709_141351.jpg
to this...http://i833.photobucket.com/albums/z...709_141403.jpg
and this...
http://i833.photobucket.com/albums/z...709_141730.jpg
Step 11: At this point the whole thing is pretty solid but i wanted to be sure air wasn't catching on things and would flow smoothly so I added tape to the car's connection points like so:
http://i833.photobucket.com/albums/z...709_140804.jpg
I'm not a fan of the tape color, I'll either paint the tape green or find green tape soon.
Check out how little of the window is actually blocked with the addition of the plexi-window:
http://i833.photobucket.com/albums/z...709_142336.jpg
View from back:
http://i833.photobucket.com/albums/z...709_143345.jpg
Because I screwed the plexiglass window in at the four corners then into the middle (rather than from the middle out) it caused the top of the kammback to bow or sag a bit:
http://i833.photobucket.com/albums/z...709_142225.jpg
To fix this I added a brace that simply pushes out from the window:
http://i833.photobucket.com/albums/z...709_143725.jpg
Here's the finished product:
http://i833.photobucket.com/albums/z...709_142302.jpg
Daox 07-13-2011 09:13 AM
Nice job. Have you done any testing with it?
MetroMPG 09-29-2011 10:16 AM
I like the window idea.
My only other comment is it's probably best to try to avoid "hard" corners at the transition from the "top" surface to the "side" surfaces, if possible. But with this construction technique, that's harder to do.
gone-ot 09-29-2011 05:03 PM
..."soften" the corners with Duck-Tape™ (ha,ha)
brucepick 09-29-2011 09:00 PM
Just saw your gas log - nice work!
Over 50 mpg on your latest tank.
Geo Metropolis 09-30-2011 01:11 PM
yeah, if i did it again I would try to soften those corners. I don't think that would have been hard to do, but i didn't realize that mattered until much later reading one of your posts on someone else's kammback ideas. I think I could have bent the aluminum to be curved along the back edge and made it round toward the back. I'm not sure the coreplast would have liked that bend but I could do it in ABS or something.
My main tactic has been build what others have proved to work rather than test stuff myself but lately I've really been wanting to do a tuft test just to find out what's going on and identify possible tweaks that would benefit me.
Geo Metropolis 09-30-2011 01:12 PM
Thanks! :thumbup: That's been my goal for so long and it felt so great to actually achieve it!
neanderpaul 10-19-2011 10:32 PM
What kind of speeds were you traveling to break 50 mpg? I thought metros could do that routinely. Or is that only the previous gen metro? Is yours the 3 cyl? Festivas hit 53 routinely but that' driving 55.
zzz9395 10-20-2011 09:27 AM
zzz9395
liked your build.
looked up an old intrest of mine,building coroplast model airplanes.
Lots of coroplast building meathodes here.
www spadtothebone com/resources htm
hope this helps "smoothing out the edges"
Cheers
wouldn't let me post a live link...
fill in the dots!!!
Cheers
narftroz 10-21-2011 04:29 PM
does that coreplast really hold up to winds at freeway speed? i have watch tarp after tarp fall apart from the buffeting winds at freeway speeds. I know it is much thicker but has anyone had long term success with it? just curious before i try anything with it.
thanks.
Geo Metropolis 10-26-2011 01:38 PM
Originally Posted by narftroz (Post 266618)
does that coreplast really hold up to winds at freeway speed? ... I know it is much thicker but has anyone had long term success with it? just curious before i try anything with it.
thanks.
Yes, it does hold up well so long as you seal up the leading edge with packing tape, sign vinyl, something like that. Don't use the kind of duct tape I did here. In extreme heat the glue breaks down and I did have an incident where the wind got under it and pulled back some of the coreplast. Now that I have it sealed with vinyl I have had no problems for months and months and months through all sort of weather and driving conditions.
I did do some new stuff yesterday that I think people will like but i'll need some time to download the pics and write it up.
brucepick 10-26-2011 09:29 PM
What is sign vinyl??
As for packing tape = clear packing tape = it won't wreck your paint?? Or is the car's finish expendable now??
Geo Metropolis 10-27-2011 12:57 AM
Yeah the metros one generation before mine that were xfi's can break 50 pretty easy. Mine is a 3 cylinder but it's an LSI and a generation newer which makes 40 it's more regular spot. My 3 tank average is 49.95 right now so that tank is looking even better and not just a one time thing. I keep it to about 55 though I occasionally pulse and glide between 65 and 50.
The other day I took it up to 85 to catch up to a big wind breaking vehicle on a long freeway trek. It was amazing how quiet and well it handles that speed with all this aero. Previously the car would scream in protest as all three cylinders worked their tails off but it seems like now that is no trouble for the car at all.
Geo Metropolis 10-27-2011 01:50 AM
Here is a link to a writeup I did about sign-vinyl - it's pretty awesome (the vinyl that is, not my writeup)
You know I used packing tape to secure my front fender splatts which were a super ghetto cardboard monstrosity. I was really nervous about doing it because I was sure the packing tape would be bad for the paint. I had every intention of removing them very quickly but they ended up on the car for 3 months. I removed one yesterday and I gotta say it came off pretty clean and easy. My paint is in decent shape so it doesn't want to come off but I was surprised anyway. I'd bet if you removed it carefully, maybe used a heat gun, packing tape could be an ok option even though my reaction was pretty much :eek: the same as yours
mjspiess 11-23-2011 02:56 PM
Mine doesn't have a window, but it is a one-piece coroplast. I've had this setup for 2 years with now issues.
http://carphotos.cardomain.com/ride_...6_original.jpg
