Old 01-17-2017, 09:22 PM   #1 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Bigger than normal MPG drop?
Has anyone else noticed a bigger than normal hit to mpg? I typically get around 24 in winter and now I'm getting about 22. I normally wouldn't be concerned but i have 6, soon to be 7 consecutive tanks below average. My route doesn't change, 56 miles straight highway with no traffic except the last 5 miles.
I got a new battery and set of tires right before the decrease, 3k miles ago. One half of the engine injects about 10% more fuel than the other, but it has been that way since i got the car.
Anybody else seeing lower than normal fe?
Edit: looking back at '14/15 i see that my mileage is in line... perhaps last year was more mild than i thought. But this year has been rather mild also... idk.
Old 01-17-2017, 11:00 PM   #2 (permalink)
ScanGauge <3
ThermionicScott's Avatar
It's been pretty mild in my area as well. I wonder if your ECM "relearned" something incorrectly after the battery was reconnected. Those 6 or 7 tanks have all been since then, right?
Being a software nerd, I can't help but wonder if disconnecting the power and trying again might clear it up.
Best tank (so far): 32 MPG
Old 01-18-2017, 10:37 AM   #3 (permalink)
My guess is that it is the tires.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Ecky (01-31-2017), Fat Charlie (01-18-2017)
Old 01-18-2017, 11:18 AM   #4 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.93 mpg (US)
Another vote for the tires.
A tire data point: The local rural mail delivery guy has a Prius. His mileage drops 3-4 MPG when he puts his winter tires on.
Temperature could be part of it. My truck mileage changes almost exactly 1 MPG for every 10 degrees F temperature change.
Old 01-30-2017, 08:27 AM   #5 (permalink)
Update:
Since temps have come up a bit, but now gone back down, the last 3 tanks since 1-18-17 have been 24 to 25 mpg. Wich is pretty normal. I think the low mpg was probably to do with the weather. Though i also noticed the mpgs drop very quickly above 70, 2 to 4 mpg hit between 70 and 75. Cam phasing must be doing something around 2100 rpm.
Old 01-30-2017, 10:21 AM   #6 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
3 tanks in less than 2 weeks?
Old 01-30-2017, 10:36 AM   #7 (permalink)
ScanGauge <3
Doubt it's anything to do with your cam. Speed kills for all of us. Do you need to be driving over 70 MPH?
Old 01-30-2017, 03:59 PM   #8 (permalink)
Yes 3 tanks, i drive 57 miles each way to/from work.
Don't need to be, but sometimes i do. My thought is that as the drag increases, the throttle position gets to the point where the cam phasing starts to engage.
Old 01-31-2017, 07:46 PM   #9 (permalink)
90 day: 19.36 mpg (US)
10% drop is reason for investigation. This rule was old when I first heard it in 1970s. Fuel and air filters first back then. Next was spark plugs and points. These were after tire related.
Old 01-31-2017, 10:23 PM   #10 (permalink)
Its really odd, ever since i got the car it would ping with regular gas and then feel like a monster (for what it is) on premium. Now lately, the last couple months, it hasn't been pinging on regular and holds gear with much more throttle input.
I know there is something wrong since one side of the engine injects about 10% more fuel, the o2 sensors and cat temperature confirms this. But i dont know if it is the o2 sensors or the timing chain stretched.
I found out i have wideband o2 sensors stock, how do i view the afr?
