Old 12-28-2012, 08:37 PM   #1 (permalink)
Well, I tried (marine plastic wheel covers)
I have seen many discussions of marine plastic whenever someone used or considered something else, so I ordered a 14'x10' sheet from Boat Shrink Wrap Construction Wrap 14. That was more than I wanted, but ten feet was the minimum length--$2.18 per foot, with free shipping. I bought a heat gun and tonight I tried it out.
I wondered how it would ever work, I needed to be able to attach the lugnuts!
It shrunk pretty well, except at the edges, and where I had slit it to fold around the back. The last picture shows a hole on the edge--that came all of the way from the back!
When I try again I will cut a slightly larger piece, cut out holes for lugnuts, and put a five-pound weight or something to hold it down as I shrink the rest to fit.
We will see how it goes, but it takes a while!
ID:	12124   Click image for larger version
ID:	12125   Click image for larger version
ID:	12126   Click image for larger version
ID:	12127   Click image for larger version
Sven7 (05-25-2013)
Old 12-28-2012, 08:51 PM   #2 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
I haven't used this particular product, but I use (much thinner) heat shrink at work.
The weight in the center sounds like a good idea, but I wouldn't try cutting holes for your lug nuts until after it's been shrunk in place. Any holes or cuts will spread during the shrinking process.
Old 12-28-2012, 09:01 PM   #3 (permalink)
Good point! Thank you very much!
Old 05-24-2013, 07:55 PM   #4 (permalink)
Well, I failed again. I ordered these hubcaps Amazon.com: CCI IWC413-15S 15 Inch Clip On Silver Finish Hubcaps - Pack of 4: Automotive that I mentioned in http://ecomodder.com/forum/showthrea...tml#post314630 and I was all ready to ecomod, but my stock rims are completely different than others that I have seen. I think they are more attractive and hope that they are lighter, but they absolutely do not fit these hubcaps!
Old 05-25-2013, 12:58 AM   #5 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
How does it stay put around the edges? Seems to me it would want to pull itself back over.
Old 05-25-2013, 06:42 AM   #6 (permalink)
Well, the first one was a disaster. The I slit the plastic and it atrophied and disappeared wherever I cut it. I did not try the marine plastic with the new ones because I could not mount them on my rims.
I do not know if I will have the opportunity to try again, I may only be able to use hubcaps like mine on my Subaru, and the lugnuts complicate everything.
I guess that I will just fiberglass over everything!
