EcoModder.com
-   -   Hx wheels or 14" hybrid wheels? (https://ecomodder.com/forum/showthread.php/hx-wheels-14-hybrid-wheels-29305.html)
Hondamate 06-21-2014 06:34 PM
Howdy, I bought an hx with some ugly wheels on it. What you you all recommend the hx wheels or the hybrid wheels. They both weight the sAme(11 pounds), but I think the hybrid wheels maybe more aerodynamic.
UltArc 06-21-2014 07:05 PM
Insight rims with RE92s :thumbup:
Hondamate 06-21-2014 08:15 PM
what size tire mate ?
UltArc 06-21-2014 08:46 PM
http://www.tirerack.com/tires/tires....t&autoModClar=
MetroMPG 06-21-2014 10:03 PM
I'd also go with the Insight or Civic hybrid rims. RE92's on the Insight rims are probably the best overall bet, as UltArc mentioned.
Hondamate 06-22-2014 02:45 PM
Having a hard time locating a set if insight or hybrid wheels. Insight tire siZe is 165/65r14 hybrid 185/70r14. Hybrid is like 2 inches taller. I drive mostly high way would recommend going with the wider tall or stick with the smaller shorter tire if the insight?
tvbd56 06-22-2014 03:24 PM
I was able to get a set of 175/70R14 for my CRX. Maybe take a look at that size
2000mc 06-22-2014 04:04 PM
sounds like the perfect opportunity to try your hand at DIY covers, if ya booger up a wheel too much then buy new ones
Hondamate 06-22-2014 09:08 PM
I think I will. So, you do recommend larger siZe tire then for the hi way.
Yeah, the insight and hybrid wheels where both about $1200. The hx are only $600 for new ones. Have to think about it. Might have to use some pizza dishes, lol.
user removed 06-22-2014 09:16 PM
I would go for the smooth wheel covers unless you need tires anyway.
Is the child safety lock engaged on your passenger rear door?
regards
Mech
