Old 06-26-2021, 03:14 AM   #1 (permalink)
What's a CEL anyways? :confused:
Until now the newest car I'd owned was a 1979 VW. Now I've got this 1990 Metro and it has a learning curve. Clickbait title -- I know what a Check Engine Light is. I've done my due diligence, I gave Google two pages to find a result.
The situation. Turn the key on and the light flashes a 12. Which is supposed to be 'cleared for flight'. Don't know why I hadn't noticed it earlier.
But lately, on the road and under power there's nothing, but at a slack or trailing throttle it throws random ones, twos and threes.
Help me Eco-modder, you my only hope.
Old 06-26-2021, 10:16 AM   #2 (permalink)
Crud, OBD1 & it's cryptic coded messages that don't help diagnosis. You need a paperclip to start self check.
Firstly, a good decrudding of the ground connections is in order, along with a long grok of the description of cause found somewhere online. It's 20+ years old and a lot of the control harness has become brittle and inflexable, subject to intermittent signal when the engine moves on decel...
If the light doesn't stay on, it technically isn't a CEL. It needs to be ON or flashing about once a second.
freebeard (06-26-2021)
Old 06-26-2021, 12:47 PM   #3 (permalink)
They are one second flashes. I'll be asking the mechanic I bought it from, but I can't reach him on the weekend.
Another oddity is that when the gas gauge registers Full, there's a bright dot to the left of Empty the back of the gauge.
At least it keeps life interesting.
Old 06-26-2021, 01:04 PM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Ones twos threes? Isn't it supposed to show some of these numbers:
https://www.troublecodes.net/gmimport/
Old 06-26-2021, 01:52 PM   #5 (permalink)
That's the list I'd found. I get the 12 on ignition on, which is reassuring, but there are no single digit codes, which suggests some intermittent electrical fault.
Piotrsko -- Can you explain about the paper clip?
Old 06-26-2021, 03:03 PM   #6 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
You can find a how-to and codes on GMF:
https://geometroforum.com/check-engi...guide-t10.html
Old 06-26-2021, 03:36 PM   #7 (permalink)
The paperclip is rebent to assist shorting 2 female pins on the obd connector typically in the engine compartment thus forcing the computer to barf appropriate codes somewhere on the panel ostensibly to aid in fault diagnosis. Which pins? Model and maker specific.
