Old 06-07-2011, 02:31 PM   #1 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
MIT Liquid Fuel Battery
This is interesting. Some MIT students put together a new style battery.
We'll see.
Here's the article. MIT Figures Out a Way to Refuel Electric Cars with Liquid Fuel - Technology - The Atlantic Wire
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 06-08-2011, 12:17 AM   #2 (permalink)
kir_kenix
kir_kenix's Avatar
1997 Chevy s10 - '97 Chevy S10 WT
Pickups
90 day: 32.71 mpg (US)
1997 Ford Escort - '97 Ford Escort LX
Team Ford
Last 3: 32.29 mpg (US)
Razz - '97 Yamaha Razz
90 day: 109.57 mpg (US)
2004 Ford F250 - '04 Ford F250 XLT
90 day: 16.32 mpg (US)
2000 S10 4.3 - '00 Chevrolet S10 W/T
Pickups
90 day: 19.4 mpg (US)
2010 corilla - '10 Toyota Corolla LE
90 day: 32.82 mpg (US)
'Yota - '22 Toyota Rav4 LE
90 day: 37.41 mpg (US)
I'll be following these developments. My chemestry prof. mentioned this today during class. Seems like this might be a viable option to the electric car "problems" (range, charge time, battery life, battery size, battery cost etc). Hopefully we can figure out a way to do something with this and make it work.
Old 06-08-2011, 11:11 AM   #3 (permalink)
ReVolt Enthusiast
Aren’t fuel based batteries called “Fuel Cells” ????
There are already Liquid and Gaseous based fuel cells.
What's the difference ?
Old 06-08-2011, 12:05 PM   #4 (permalink)
I think (the report's not completely clear) the difference is that you can also charge this battery, unlike a fuel cell. So you can charge it at home for short trips, have the benefits of regenerative braking while driving, and on long trips stop at a goo station for a replacement charge of goo.
If I'm understanding their design correctly, it also seems that you could easily change the amount of goo in the system, so you'd have a lighter system for everyday use, and for longer trips you could plug in a couple of extra goo modules.
Old 06-08-2011, 12:08 PM   #5 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Mmmmmm, goo....
Old 06-08-2011, 12:49 PM   #6 (permalink)
This isn't a "fuel battery," it's a Flow Battery. You can Google it or try wikipedia to get a better description but generally; Flow batteries allow storage of the active materials external to the battery and these reactants are circulated through the cell stack as required. A flow battery was used in 1884 by Charles Renard to power his airship La France.
The technology was revived in the mid 1970s. Modern flow batteries are generally two electrolyte systems in which the two electrolytes, acting as liquid energy carriers, are pumped simultaneously through the two half-cells of the reaction cell separated by a membrane. On charging, the electrical energy supplied causes a chemical reduction reaction in one electrolyte and an oxidation reaction in the other. The thin ion exchange membrane between the half-cells prevents the electrolytes from mixing but allows selected ions to pass through to complete the redox reaction. On discharge the chemical energy contained in the electrolyte is released in the reverse reaction and electrical energy can be drawn from the electrodes. When in use the electrolytes are continuously pumped in a circuit between reactor and storage tanks.
Old 06-09-2011, 08:02 AM   #7 (permalink)
ReVolt Enthusiast
Thanks for clarifying that.
I have never heard of “flow batteries” before.
Looks interesting, here is a good diagram …..
Storing Sunshine Using Flow Batteries >> MetaEfficient Review
- Mark
