EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   I have a confession.....I was spoiled...... (https://ecomodder.com/forum/showthread.php/i-have-confession-i-spoiled-23001.html)
mcrews 08-20-2012 03:13 PM
I have been north of San Antonio now for 3 months and have come to a realization.
I was SPOILED!!!!!!
Now, understand, I am happy as a clam to be uot of Sacramento California.
But what I have come to realize is that Sacramento was actually pretty dang flat in comparison to the Texas foot hills.
It was very easy to get good(28+ mpg) in the Sacramento area.
It has been difficult to break 26mpg here in texas.
I just drove from Austin to Dallas and back. And only got 24.7mpg w avg speed of 62mph. There are constant 'hills' along the way. (and not just the overpasses which are twice as tall as in CA.)
I quess we should start marking our mpg records w/:
1. Very flat
2. kinda flat
3. Not very flat
4. You gotta be kinding.....
I know in the beginning, I was very clear on my trips to Cedarville CA from Sacramento to state that there were 2 mountian ranges and A LOT of coasting down hill.
I can see how some one with a similar vehicle as mine who lived in the Texas Hill Country might call BS on my mileage claims.
As a amall footnote: at 262,000 miles, I 'feel' that part of the lower mpg may be engine related. IMHO, I think that I have lost some 'edge' that was there in the 100k - 200k range. Especially since the octane is 93 here in texas and only 91 in CA.
Your thoughts??
PaleMelanesian 08-20-2012 03:18 PM
Texas isn't as flat as most people outside think it is. With good stick shift skills you can use the hills for mileage gain, but it's tricky with an automatic.
Flakbadger 08-20-2012 03:19 PM
Hm. My best tank of gas was on hilly terrain between my house in Portland and my Grandparent's in John Day... There are several passes over 3k feet, and 2 over 5k feet. Their house sits 3k feet higher than mine.
Then I drove HOME from there and got an even better tank. I think hilly is actually okay for MPG's if you're not doing short trips and if it's all highway. The key to MY MPG's was lots of engine-on coasting down hills, sometimes in neutral, sometimes using compression braking [EDIT: Probably a lot harder in your automatic :P ].
262,000 miles makes me wonder if you might need a tune-up... And wouldn't 93 versus 91 octane benefit your car? Higher octane should be a good thing.
[EDIT 2: I misread that one. You were saying your car MUST have lost some edge since you are getting fewer MPG's on higher octane. Derpy me.]
Either way, your build threads are awesome and you have nothing but respect from me.
:D
~Matt
mcrews 08-20-2012 03:41 PM
Pale, I was born in Dallas and kinda took the 'rolling flatness' for granted. The rolling hills dont help coasting.
mcrews 08-20-2012 03:48 PM
:D
~Matt
Matt,
first, thank you for your kind words!
I am always humbled to see that my underbelly thread has over 14,000 views! :o
I am pretty religous about the tune ups, although it's mainly repalcing the iredium plugs every 80k. I use synthetic oil and chang it and filters every 9-10k. I blow out the air filter about once a month.
You are spot on w/ your trip description! The prblem here in central texas is there is not enough elevation decrease to coast.
On a trip like yours (and my trip to Cedarville) there is alot of potential downhill coasts.
I 35 is pretty crowded and I just have never got used to P&G. (except on steep downhills)
MPGranger 08-20-2012 04:12 PM
You want some serious downhills, you need to try Tennessee! My wife wanted to take a detour there the last time to Pennsylvania. Started going downhill, threw the mini into neutral. Got to 75MPH in neutral, put the mini into 6th gear to slow down a bit. Got to 85MPH, threw the mini into 5th to actually attempt to slow down. There were trucks and SUVs and Minivans passing me, but I wouldn't want to perform any of the turns anywhere near them. I know my mini handled much better than at least 95% of other vehicles on the road.
user removed 08-20-2012 04:15 PM
Make sure your calipers aren't dragging more with that age and mileage.
regards
Mech
mcrews 08-20-2012 04:23 PM
Mech,
Thanks for that. I had just changed the rotors and new pads.
mcrews 08-20-2012 04:29 PM
regards
Mech
so fyi.....is there a way to check this????
roosterk0031 08-20-2012 04:36 PM
I check mine for one hotter than the rest after driving. Touch the rims first then carefully check the rotor, harder with drums. A real remp reading would be better, but I get by doing a manual especially if I smell brakes.
