I have solar telemetry now and the results are in
60% of the energy I use is generated by solar (and most of that is generated locally).
And of the rest I'm counting natural gas and gasoline in that total (the women who must be obeyed in the house want nat gas instead of induction so even if as I add more solar and LifePO4 storage, I may end up keeping the gas stove. Being a poly lesbian isn't easy) otherwise I could cook the numbers to make it 69% solar. Since projections say that it's going to get a good 5C hotter here before I'm dead, I'm trying to be ahead of the curve and ensure that I don't die in the heat. Plus battery storage is about the same cost as pulling from the grid and it's a lot harder for someone to hit my roof with a car. |
What part of CA is projected to go 5C warmer within a lifetime?
In general, warming increases the coldest colds far more than the warmest warms. That means that in general, HVAC costs should decrease. Of course, specific locations will vary. So far this year, I'm almost at break-even on solar production vs electrical consumption, but have started using electricity for 90% of transportation. I'm hoping to get away with using a more efficient 1-ton AC unit vs the inefficient 5-ton this summer to help offset the EV consumption. |
Which would be easier: more solar panels or a super efficient heat pump head unit?
Suspect the 5C increase is in the central valley. They are changing the color of the land, fubaring up water sources and adding people. |
