I may have finally found my HX!
1998 Honda Civic HX coupe, 5spd, A/C
http://images.craigslist.org/00a0a_l...WR_600x450.jpg http://images.craigslist.org/00z0z_6...kR_600x450.jpg http://images.craigslist.org/00Y0Y_l...W7_600x450.jpg http://images.craigslist.org/00404_j...YX_600x450.jpg Quote:
My Ultragauge shows low 30s on the freeway, but it is showing 25.8 overall. Should I check it out? |
Absolutely check it out. Looks clean. Bring your UG and test drive it, looking for AFR indications of normally operating Lean Burn.
I am trying to find the AFR part of the manual, but it keeps hitting "calibration." I did find a part about Injector Cutoff, it will not detect it by default.
Ultragauge, you have failed me! I found something about the Air to Fuel ratio, but it just talks about Lambda, not how to display it. So, I should Plasti-Dip a Civic? :) I am pretty sure that would look terrible, at least if I did it... |
Plastidip adds a fair bit of weight, too.
It needs quite a few layers, certainly if you want white on a black car, and they tend to add up. |
Black cars are cool. And hot.
