EcoModder.com
-   -   I Might Have Hit The Wall Today (https://ecomodder.com/forum/showthread.php/i-might-have-hit-wall-today-3880.html)
Big Dave 07-17-2008 04:24 PM
I always thought I could get to 30 MPG with this truck, but to do so I needed more help from my gearing. I figured an overdrive could do it.
Wrong!
It mght get me to 30 MPG, but I'd need to be Bill Gates to afford it.
First, the nearby US Gear rep - a respected and reliable firm told me the no longer installed US Gear overdrives because they could not get parts. That's sad. US Gear was once reliable, but US manufacturing is in free fall so it is a plausible problem.
Gear Vendors is still in the business, but the quote was $5,000 installed. $5,000! To justify that I'd have to drive more than the distance to the moon - 278,000 miles or so.
Maybe its time to admit I've gone as far as possible and get something else.
elhigh 07-17-2008 04:39 PM
Ah, man that stinks. And with your axle, I reckon 3.08 is as low as they go.
Hey, you never know - Bill Gates might just read this and give you a call?
Still, over 26mpg on an F-350 is huge - the EPA guesstimate for the F-150 is only 19mpg highway, I'd reckon the 350 with its heavier everything would probably rate way lower. So you're still ahead of the game.
Look at it this way: I'm struggling to get the same kind of mileage from my Subie Forester. Half the size, half the power, same mileage.
Add a bellypan and see what that gets you? Or fender skirts?
metromizer 07-17-2008 05:57 PM
Assuming you are not hauling anything in that 1-ton, how about switching to a lighter duty transmission and rear end from say, a wrecking yard mustang? There may be taller factory 5th gears and R&P's available if you selectively mix-n-match. Your FE would surely benefit from light duty parts and the lower parasitic lossses, when compared to the huge gear contact areas and hypoid contact patch the F350 parts have.
The other way to look at this... heck, is it's your hobby! Golf green fees are getting up there, fishing requires a boat... spend that same dough on an overdrive unit to prove a point with your truck (afterall, if you were just after a cheap commute, an F350 wouldn't be anyone's first choice) I say dam the cost, look past the paper calculation and go for it if you can afford it.
zjrog 07-17-2008 06:39 PM
Almost 27 with that monster is still great... I'd love to get that with my Jeep. If I was driving it more right now I'd just be happy with 25, since I already passed my first goal of 22...
Dust 07-17-2008 06:43 PM
Are you diesel? Some vendors have come out with a MPG water/meth kit. Might be something to look into.
gascort 07-17-2008 07:36 PM
Just drive it.... maybe the transmission will go out and you'll have an excuse to smile (just a little bit) when it breaks!
x2 on the wheel skirts
Johnny Mullet 07-17-2008 09:09 PM
You have really set the bar high for all truck owners looking to get better fuel mileage. I would keep going! You can't hit a wall with that thing because it will go right through it!
reformed 07-17-2008 10:10 PM
Haha, I just got the theme of your "Nice Road Trucker" thing. Good show, but I can't stop watching "Deadliest Catch".. don't ask me how I relate those two shows together.
Anyway... I second the idea of an 8.8" transplant from a mustang. You will have to switch your rear rims to make it cost effective, but you can get at least 2.73's for an 8.8". I have an 8.8" in my mustang and it withstands 550hp launches on slicks consistently w/o breaking.. the stock 28 spline axle's are another story, but they will hold fine if you aren't beating on it... which somehow I doubt you would be, given that you're getting almost 27MPG in a 350.:thumbup:
Edit: come to think of it, I remember reading that some Excursions had 2.73's.. maybe something worth looking into also.
Duffman 07-17-2008 10:31 PM
I would go to a 5.9 cummins before I would put that kind of money into an OD. There should be a significant amount of friction reduced with a cummins because it is a six and has less CID. I know, I know big bucks too, but that would be the hot ticket IMO.
Big Dave 07-17-2008 10:52 PM
I've tried to keep the truck true to its mission. It can tow and haul just like stock. But a lot of these heavy-duty components limit my options.
Maybe its time for a different vehicle. Two options would be either a Chevy 4x2 half-ton or a 1994-96 Caprice. Both use the same drive train.
I can get either of them converted to T-56 Corvette six-speed. The T-56 has two overdrive gears. Fifth is 0.71:1 (about what most overdrives are) and sixth is a whopping 0.5:1.
The light-duty GM axles host gears from 2.47 to 4.88.
There are a ton of slam kits for both vehicles.
The engine choice would be either a GM 6.5 or a Cummins 4BT3.9 diesel.
Both offer some scope for aero-mods.
I can get either vehicle fairly cheap - $3,000 to $6,000. The low cost allows making exotic moves.
With either, I think 35 is possible and a project done for under $12,000.
