I want to build a 100-mpg car (and I want it to look vintage)
3 Attachment(s)
And I want it to look vintage.
100 mpg at 60 mph. What do you think it would take to accomplish this? Single-seater, center-steer, possibly mid-engine, probably a 4-cylinder. I love the looks of the *BOcruiser. And the Phantom Corsair. Hudson Hornets. This custom Metropolitan (they weigh 1750 pounds). |
(I base these figures on the real-world construction costs of a - much simpler - Lotus 7 replica.) I used to think about making my own car (and I have the workshop tools, space and most of the skills) but then I figured a Gen 1 Honda Insight is a far better outcome than I would ever achieve. |
What mpg does the Insight get? |
So, how are going to get drag low - and build the body? Hand-beaten aluminium? Fibreglass and moulds? And how are you going to know it's low drag - bespoke models in a high speed wind tunnel? How are you going to keep the engine operating at its peak? etc etc Manufacturers have the best engineers around and spend literally billions developing new models. How much did the Volkswagen XL1 cost to develop? And I bet they amortised basically none of that development cost - and each car cost $144,000. To be brutally honest, developing a proper car that matches your requirements I think is nearly impossible these days for a private person. At least, for one without a lot of money and time to spend. A dead standard Insight can do about 84 US mpg at a constant 60 mph (no pulse and glide, etc). |
A vintage looking car isn't going to have the aerodynamics to get great mpgs.
I think you might make it by using mpge rather than mpg. Yep, put an electric drivetrain in it and triple the efficiency. Then you could use the vintage format but do a retro version that decreases the drag to no more than 0.24. You implied you could go with a single-seater so it doesn't appear you are worried about the size. That means you have the capability of keeping the frontal area very low. If you insist on carbon fuels I would go with a diesel engine where legal and use a form factor like Dave Cloud's Dolphin.
JJ |
Electric vehicles aren't free mpg. To convert to mpg properly you have to consider the cost of the drive rather than the watts involved. For most people electric vehicles are more expensive to drive unless you can charge them at home cheap or have access to free charging.
For example, a person I talked to would spend $5 to charge their Prius Prime battery, for 25 miles. That's $0.20 per mile. At 60 mpg in hybrid mode and $3/gallon running on gas would be $0.05 per mile, making electricity 4x as expensive, giving them an equivalent mpge of 15 mpg, even if the Prius readout claimed "199.9 mpg". Vintage vehicles are typically larger and less aerodynamic. A few models were produced for aerodynamic efficiency, but would be hard to find. And it would need to be smaller or more aerodynamic than the already crazy efficient G1 Insight. Drivetrain could be from a G1 Insight, but then you'd have to fabricate custom mounts, etc. for it. There's a guy on here who swaps Prius drivetrains into classic cars, but his projects take a very long time. Aerocivic.com might be worth checking out. |
Some people are dumb.
If you are not charging at home or some place that is free and paying to charge you are spending nearly as much if not more than what you would spend on gasoline. |
https://www.youtube.com/watch?v=tAYY...=RickBlekestad Drag coefficient is only part of it, frontal area is too. If you are building a car and it has to look old then it is hard to have both old look and low drag coefficient. |
A car with four wheels and two seats? A kit car with a fiberglass body powered by a 3 cyl. diesel would be the simplest. If you want only a single seater then streamline a smaller motorcycle, 250cc Honda liquid cooled, as those in the Vetter Challenge.
Ah ****, I just lost my reply- I give up.
My plan is to start with an old car and modify it to be shaped like the BOCruiser, choose an engine that produces the horsepower needed to move it at 60 mph near its maximum efficiency, and add a turbocharger for accelerating (if needed). |
Hey wasn't there a guy who put a 3cyl kubota diesel in a metro and was getting around 100mpg?
https://diesel-bike.com/Centurion/ce...cs_600x231.jpg https://ecomodder.com/forum/showthre...xed-23497.html There was a guy who did a kubota swap in a metro, but I don't think he ever got it on the road (atleast not that he mentioned in his thread) https://lh3.googleusercontent.com/pw...-no?authuser=0 https://ecomodder.com/forum/showthre...geo-32945.html |
Maybe I am pretty slow, but just turbocharging my Insight and fitting and mapping the engine management was, for me, a year-long project on its own. And I have done turbo and electronics work on cars plenty of times before! |
Thanks for not getting half done before asking for opinions. :)
Personally, I'd be most comfortable with a Beetle floorpan. https://ecomodder.com/forum/member-f...ve12d2-509.jpg https://ecomodder.com/forum/member-f...945-veyron.jpg https://i.imgur.com/6SENw.png The taper at the front compared to a Ghia/Type III pan will accommodate modern front wheelwells and a beam extender can increase the wheelbase by ~8". https://ecomodder.com/forum/member-f...gt-one-tm1.jpg To accommodate the rear engine follow Luigi Colani: https://ecomodder.com/forum/member-f...ni-desktop.jpg https://ecomodder.com/forum/member-f...-c-form-02.jpg <airframe//powerplant> You can put almost anything on a VW bellhousing. Pinto, TDI diesel, electric, & etc. For a pure electric, the Lexus Highlander 68hp axle. For a hybrid boxer or inline three/four, the GM E-Assist serpentine belted 20hp altermotor. ______________ Else, clone Aerocivic. |
It's a charging standard.
They're modular. My son gave away the Ghia I bought for him when he needed a car [in 2012].
But, '61 Comet? :thumbup: |
(It was just that you said you wanted 'an efficient engine operating at its peak' and to get that, engine management is obligatory.) |
1 Attachment(s)
do forget to knit your self some seatbelts https://ecomodder.com/forum/attachme...1&d=1601628084 |
As mpg_numbers_guy said earlier, the Insight is a great point of reference. In stock form, using exreme LRR tires which sacrifice handling and traction, with the inflation pressure raised to 45+, and a few minor aero mods (partial grille block), the Insight is capable of 100mpg @ 50mph. As speed increases, that fuel economy drops significantly. I want to say that at 60mph, it's closer to 80mpg.
https://ecomodder.com/wiki/Vehicle_C...t_of_Drag_List The Insight has a 0.25 drag coefficient (very low), a frontal area of ~20 sq ft (very low), and an engine whose peak thermal efficiency is just as good as the best from Toyota and Honda today (~40%) - albeit with a lower output than Toyota and Honda's current best. My thinking is, you'll need an engine that is no less efficient than the Insight's, which is a very short list. You will also need to beat it in both coefficient of drag and frontal area. Diesel helps - the fuel contains ~15% more energy content, but you also usually pay more for it so it may not win in cost per mile. If the goal is cost per mile per unit energy, going electric in an area with cheap electricity may be the easiest way to achieve this, but you have the upfront costs of the batteries. From the Urban Centurion thread, Quote:
Many 'do' was a typo and it's just incoherent otherwise?
100-mpg @ 60
I abandoned my project simply considering how traffic behaved around me when on a motorcycle. Americans are sociopaths by default. They won't follow at a safe distance and going up against a 3.5-ton projectile is more than I want to contemplate. The guy who bought Three-Wheeler's 1st-gen Insight boat-tail is routinely seeing 80-mpg on the open road. And it's 5-star safety rated. Pay attention to Julian's wisdom on this one! I've already lost a brother to an SUV. I don't want to hear about you. |
Build to pass a tech inspection at some race track, SCCA, NHRA, 24 Hrs of Lemons, etc. |
Jack McCornack used to be on this forum.
https://www.motherearthnews.com/gree...r-zm0z13amzmar
It could be a starting spot. I agree with FreeBeard about using the classic VW bug platform as it gives you a multitude of kit car choices for bodies. You can adapt various engines to fill your needs. The suggestion of a diesel as your choice for an engine is a good suggestion to follow. The choice of a Kubota 3 cylinder does not give you much in the way of tuning but does give you a high starting point for thermal efficiency without much effort. But, if I was you? I'd get a manual front wheel drive with a substantial overdrive and stick a Kubota 3 cylinder on it. Then I would cut off the back end of the vehicle and weld a substantial motorcycle frame and drive wheel on there. That back wheel will be electric drive and will provide a boost during acceleration to make your vehicle more enjoyable and safe to drive. Then build out the body in as streamlined a tadpole configuration as you can. Or just contact R. Q. Riley. https://rqriley.com/ |
Safety is a big concern. The centered seat is a part of that. I'm uncomfortable sitting right next to the door in my normal car. I want some wiggle room, if hit on the driver's door.
I'm also thinking I will include tubular structure in the body. Imagine the curved line of the aerodynamic streamlining template as a roll bar. I've been looking at the mpg calculator. To reach 100 mpg at 60 mph the drag coefficient, frontal area, and weight will need to be minimized. |
tubular structure
They'll lay out chassis and roll cage construction to the Nth-degree. Gumby-79s working through the SCTA book right now for his attempt on the salt, once COVIDs behind us. EASTWOOD Publications has many a reference on fabrication ,as does You-Tube |
Then build a single or inline seater. No problem.
Fiberglass over foam is easy to do at home with patience. It also provides significant strength and impact absorbing properties ( think surfboards and skis) requiring minimal steel/aluminum under-structure. Unless you really do want the extra NASCAR roll-cage. |
I don't want a full rollcage, just some decent protection. I plan to work with metal. Freebeard's going to have to build the VW, at this time. |
There was a time when using Beetle parts made more sense. Same with 2CV.
https://ecomodder.com/forum/member-f...-p1000641n.jpg Quote:
https://ecomodder.com/forum/member-f...11-5-38-12.png |
Vintage styling doesn't weigh any more than any other styling. Thanks for all of the replies. Notice how they are mostly stemming from the human negativity bias? |
