EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   If you must have outside mirrors, at least make them doubly useful (https://ecomodder.com/forum/showthread.php/if-you-must-have-outside-mirrors-least-make-33545.html)
MetroMPG 03-04-2016 02:36 PM
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1457120117
Well, I'll be....
the mirrors on the K-Pax Racing McLaren 650S GT3 have a purpose: they help funnel in air to cool the interior of the car
Source: Black Flag
RedDevil 03-04-2016 04:12 PM
When I was still biking I once, while riding on the highway in the evening, got struck on the chest by a not entirely empty strawberry milkshake beaker that was thrown out by some @&€ just ahead. That covered me and my bike all over. McDrives, gotta love those.
I wonder what would happen if that beaker struck that mirror...
Would be fine for use on race tracks though.
Frank Lee 03-04-2016 04:22 PM
And if the vent is closed the aero isn't hurt.
P3T3R5ON 03-16-2016 12:13 PM
The over engineered dream car... the Lexus LFA does some fancy aerodynamics with their side mirrors. They are designed to funnel air directly into the rear/side air intake vents for the rear mount engine.
https://upload.wikimedia.org/wikiped...us_LFA_001.JPG
NeilBlanchard 03-16-2016 12:37 PM
Actually, I think when the intake is open, that it could lower the drag relative to when it is closed. Especially if the air that enters the car is vented out into a low pressure zone behind the car - or behind the mirror?
Frank Lee 03-16-2016 02:52 PM
We've discussed the aerodynamics of ducts at length here... right? They ADD drag unless you count the rare case of a properly engineered heat exchanger duct that adds a bit of energy to the stream via heat.
Vman455 03-16-2016 06:11 PM
The LF-A is front-engine. However, the mirrors are interesting.
http://i1047.photobucket.com/albums/...psfzdjsubl.jpg
oldtamiyaphile 03-16-2016 09:19 PM
When rain hits the passenger air intake in a regular car, you don't get wet, same solution can be applied to these.
RedDevil 03-17-2016 03:57 AM
That is the whole issue.
The mirror is mounted to the door.
If it were a road car it needs the dirt/water trap and flowoff all inside the door.
That would be troublesome.
But this is a race car, it will just have a nozzle to direct the air (and everything it contains) where it does best. The driver wears a helmet anyway.
NeilBlanchard 03-17-2016 12:40 PM
You may be right. My point, though is to shift the air through the duct means that it doesn't have to flow around the mirror, and that could reduce the drag of the mirror.
