EcoModder.com
-   -   I'm discouraged (https://ecomodder.com/forum/showthread.php/im-discouraged-21162.html)
SpencersGreenTurd 03-26-2012 08:53 PM
I'm discouraged
I'm discouraged. I have done a lot of mods to my car without much increase in mpg. Only an increase of 2 mpg. What am I missing? My car is a 93 tercel and here is a list of mods;
New o2 sensor
Warm air intake
Full grill block
Pizza pans
Lightened 200lbs
Tune up
Headlight covers
Kill switch
Vacume guage
Wheels at 50lbs
Side mirror delete
No ac or power steering
Cat detete
Please somebody help
FXSTi 03-26-2012 09:14 PM
Have you adjusted the nut behind the wheel? That is where the greatest gains can be found.
I have to question the Cat delete. I believe that part of the ECO in ecomodder is reducing pollution, both through reducing fuel use and emissions.
deathtrain 03-26-2012 09:25 PM
automatic or manual?
mikehallbackhoe 03-26-2012 09:41 PM
I agree with FXSTI on both counts,1. removing your cat might make your sensors read lean, and your computor will richen your fuel ratio, killing your mpg. 2. you haven't mentioned any changes in driving habits, which is where your biggest gains will be. I would recommend replacing your cat, and then read up on some of the hypermiling tips found on the home page. don't give up though, 2 mpg is better than nothing.
Ecky 03-26-2012 10:03 PM
I've found I can improve my mileage as much as 33% with engine-on-coast pulse and glide, and awareness of light timing.
drmiller100 03-26-2012 10:30 PM
it gets tough after 35 mpg for any car.
are you driving city or highway? average mph?
greasemonkeywithaSATURN 03-27-2012 01:00 PM
no ammount of mods can help if you dont adjust the loose nut behind the wheel like these guys said.. if you do mostly city driving then i would say your not doing too bad.
when it comes to your cat delete, there is no 2nd o2 sensor on a 93 so that shouldnt cause a problem but the lack of back pressure might be hurting you a little bit.
if you are or have adjusted the loose nut already then i would look more into possible sensor issues that may not be setting off your check engine light but may be hurting your economy. on that pre-obd2 system you could have an air temp sensor off causing it to richen the fuel mix by giving the comp a faulse reading..but dont go throwing parts at it untill you are sure, the best way is to get a scan tool or find someone who has one to plug in and read the data stream and check things like temp sensors to actual temp and if one is reading way off then i would say its a safe bet then to throw 10 or 20 bucks into it. also i had a 88 tercel and mine had bad rings and burned a lot of oil so make sure you have good compression and that kind of thing...
good luck and dont give up. keep workin on driving habbits and keep puttering with the mechanical stuff untill you get it right
Sven7 03-27-2012 01:23 PM
First of all, the difference between your first and third (last) tanks is 5.46mpg, not 2. Even if it's only 2 above EPA, you're improving. Second, you only have three tanks with very different FE numbers so no one knows what it'll top out at. Maybe your next tank will follow the trend and be better!
What driving techniques do you use, and how often? How fast do you drive on the freeway?
3-Wheeler 03-27-2012 01:47 PM
Warm air intake
Hi,
Just applying the warm air intake will not necessarily improve your mileage.
For example, if you typically drive on the freeway/highway, then you need more power from the motor, and getting this means higher density air.
If on the other hand, you puttz along on the backroads, then the thinner air will yield higher gas mileage, but only if your going let's say less than 40 mph or so.
Jim.
Kincurd 03-27-2012 02:18 PM
My slightly ecomodded car averages 37.5mpg in another driver's hands (slightly above factory rating of 37mpg). When I drive it, I get 47.7 mpg (at least the last tank I had on it was that.)
I think Ecomods more or less compliment the hypermiler. It's like installing a super-charger. Technically, the supercharger will increase MPG under the hyper-miler's gentle touch, but will kill MPG with a heavy foot.
Aerodynamics and lighter weight allow you to accelerate faster, so maybe you were adjusting to these changes more like a racer would, than a hypermiler?
Ps. Also, yeah, any tweaking to the exhaust (like removing the cat) is kind of funky. Street-racers and wannabes always target the exhaust and I think some of them simply slap on a wider opening muffler without much regard to back pressure and such.
The only exhaust mod I'd feel comfortable with is extending the muffler slightly out and tilting it for streamlining purposes, and replacing the muffler with an exact replica made of lighter materials (like aluminum or oven-cured Carbon Fiber).
