Old 11-10-2011, 05:53 PM   #1 (permalink)
waste heat engines
So anyone know of any good engines that run off of waste heat created by a cars engine?
Old 11-10-2011, 06:30 PM   #2 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
check this one out
Rotary Steam Engines: Page 9
The Following User Says Thank You to ConnClark For This Useful Post:
Rokeby (11-11-2011)
Old 11-10-2011, 06:47 PM   #3 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Look into Detroit Diesel's turbo compound system on it's new DD15 engine (15 liter engine).
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 11-10-2011, 07:29 PM   #4 (permalink)
where to buy?
those look neat
cant seem to find anyplace that actually sells just the waste heat part though.
Old 11-21-2011, 12:12 PM   #5 (permalink)
A turbocharger.
Old 11-24-2011, 08:46 PM   #6 (permalink)
cnc
AFAIK (edit ) it's a big problem to transform heat info other type of energy efficiently.
I can't propose ready to use device - only just my random thoughts. I've read something about hybrids with turbines making power for electric motors. Maybe you could borrow some ideas from them You could run small steam turbine, produce el. energy, then run an air compressor (and use the heat again), store the compressed air and use it to push pistons, let say, every second cycle. Probably you would have lots of additional issues on the way of course. It would be very complex and expensive also. Cost vs. gain could be too small to think about it seriously but hey! it's an idea
PS
Don't take me too seriously please.
BTW
Maybe it would be even better to simplify the setup. Put turbo, place high rpm high compression pump instead standard compressor and pump the air into accumulator for compressed air injector. You coould also use a heat from exhoust collector, turbo and pump. Sorry for wild imagination
Old 12-05-2011, 07:30 PM   #7 (permalink)
Steaming's Avatar
Apollo 11 - '02 Dodge Ram 1500
Saphire - '06 Honda Insight
I was thinking of scaled-up Peltier Devices that would take the heat and convert it to electricity. There is a company that makes such a device calling them Thermal Electric Generators (TEG) based in Morgantown, WV. Thermoelectric Generator
Makes me speculate about wiring a bunch into a small woodstove and throwing it into the back of a Honda Insight or something lol. I suspect there would be power/weight ratio problems, but maybe these could be sorted out.
Old 12-06-2011, 07:51 PM   #8 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Deere is claiming 18.93 hp-hr. per gal. at the pto. It has one or more heat recovery devices.
JOHN*DEERE 8320R TRACTOR SETS FUEL EFFICIENCY RECORDS AT NEBRASKA TEST
But diesel-electric as in rail or marine applications is probably more efficient over all. One challenge in automotive is running the engine at optimum load all the time. So a tiny diesel generator, storage device, and a electric drive.
