I'm I really getting 1364MPG?
1 Attachment(s)
So I was looking around on electricitymap.org and the electricity grid here in Sweden was releasing around 36gCO2/kWh produced.
And I'm getting about 9km/kWh as far as I can tell. (The instrumentation is a bit lacking) That means only 4gCO2/km or 1364MPG! :D https://ecomodder.com/forum/attachme...1&d=1626634994 |
Of course your power plants don't burn gasoline, but still an awesome number!
Congratulations, mort |
And this is why we need more EVs on the roads. Raise the MPGe and lower the CO2 emissions along as many points of the supply chain as possible.
I just wish range was better. |
Rajge is currently adequate for most purposes. Charging needs to get faster. If it takes you <10 minutes to fully recharge from numerous places on a trip, you're at gasoline capabilities. 10 minutes is a rest stop visit for me.
You dont need the 48 kv feed. That's for powering cities via substations. 1.2kv is available and at a measly 30 amps is (suprise) 36 kw. 60 amps is double that. This is typical large manufacturing factory power levels, but it does require a substation close by. Joe Average shouldn't be playing around with these power levels without some serious safety protocols that he can't shortcut.
Bigger batteries for more range just means long charging times and in a home setting that could mean days not hours and certainly never minutes. |
Viola! you just described why recharge has to change to be comparable to fuel.
The next question is what do you with all that battery heat? A ten minute refuel is probably unobtanium, so different schemas are necessary. Do you REALLY need to drive from Reno to Seattle on one tank/charge? |
MPG
In the USA, Regular Unleaded, 10% Ethanol, Reformulated gasoline contains 111, 836 Btu / gallon.
A kilowatt-hour = 3412 Btu. Giving 32.7772- kWh/ gallon Your 9-km would be 5.592 - miles / 1,000-Watts, or 178.816 Wh /mile. I'd need to know your velocity in order to give you a MPG. |
