Info & video - Opel Calibra - Cd 0.26
1 Attachment(s)
Every once in a while, GM has shown it's capable of hitting one out of the park, aerodynamically speaking. Unfortunately, this one never saw North American roads.
Here's a pic of the Opel / Vauxhall / Holden Calibra, for those who don't know it: Launched in 1989, it was designed by an American who headed GM design in Europe. At the time, it was apparently the most aerodynamic production car available anywhere. (Source: Wikipedia) Obviously they started with a decent shape. But the designers paid a lot of attention to optimizing the details as well, such as the grille openings: only the 8-valve version of the car had the Cd 0.26 figure - the 16v engine needed more cooling, which meant a bigger hole in the front, and a worse Cd of 0.29 (other contributors to the change were probably things like wider tires, chunky rims, etc). Here's another line about the small and sometimes counter-intuitive details that the Calibra engineers dealt with: Quote:
[youtube]http://www.youtube.com/v/G_NNeY7B8HU[/youtube] Some points made in the vid:
One design issue that was out of place on the slick Calibra was an outward opening sunroof (the kind that slides on top of the roof, rather than inside). In the open position, it would destroy the car's Cd. |
I find it very amazing that the little vent increases drag by over 10%.
Pretty sweet Cd on that thing, and it doesn't look half bad either.
If you understand that drag coefficients for really, really, ugly things (aerodynamically) such as the Eiffel Tower are 1.8-2.0, and that routing air through the engine bay, under your car etc is probably just as ugly, what is 10% of the CdA and hence what is the actual area of grille that would be blocked to achieve the difference? 10% of 7 square feet is 0.7 square feet. If we take the drag coefficient of that particular area as 2 (not a bad assumption), you only need 0.35 actual square feet of grille to get the difference. That's the difference a "little vent" can make. |
Very nice video. 0.26 is amazing for a car from nearly 20 years ago.
Of course, being near the ground has issues, you can get to 0.11 or so but to get better you have to start approaching an airplane by having cowled wheels and hoisting a fuselage as high as you can without toppling in a corner. But still, a Cd of 0.11 is still 10 times better than a flat plate, which is what a motorcycle or upright cyclist is basically. Another trick I learned from airplanes which the designers of the aptera seem to have learned is that you put the trailing edges of airfoils next to the leading edges of other aifoils. See this plane. If you google the AR-5 you can find more about it - total CdA of 0.88 square feet. I think what happens is that the leading edge of an airfoil creates high pressure, the trailing edge creates low pressure, and you minimize pressure difference by doing this, and hence minimize drag. |
Daox - here's another bit of info that emphasizes the aero impact of the cooling system. On a study of an un-named car with Cd 0.29, it makes up the biggest fraction of total drag: http://us1.webpublications.com.au/st...4/2455_7mg.jpg This is from the Autospeed article, linked above. Worth a read: Modifying Under-Car Airflow, Part 1 |
I was practising archaeology throughout this aerodynamics forvm when much to my delight (I'm the lucky owner of not one but two Calibras :D ) I found this old post. I can't help but resucitate it :) .
http://img37.picoodle.com/data/img37...cm_683dfdb.jpg Quote:
http://img34.picoodle.com/data/img34...cm_87f06ba.jpg http://img37.picoodle.com/data/img37...cm_d19fd36.jpg Quote:
http://img26.picoodle.com/img/img26/...sm_bd2ba78.jpg Quote:
http://img26.picoodle.com/img/img26/...sm_8a2c687.jpg Some comparisons to get perspective (Cd x frontal area in square meters = SCd, the real value): http://tbn0.google.com/images?q=tbn:...da_insight.jpg 2000 Honda Insight: 0.25 x 1.905 = 0.47625 http://tbn0.google.com/images?q=tbn:...dHoldenM_m.jpg 1989 Opel Calibra 2.0i: 0.26 x 1.93 = 0.5018 http://tbn0.google.com/images?q=tbn:...AudiA2/Ex1.jpg 1999 Audi A2 1.2: 0.25 x 2.18 = 0.545 http://tbn0.google.com/images?q=tbn:...yota_prius.jpg 1997 Toyota Prius: 0.26 x 2.16 = 0.5616 Pictures of my babies. The 2.0i (17 years & 223000km / 140000 miles and still in top form): http://img98.imageshack.us/img98/228...evla018cc3.jpg http://img34.picoodle.com/img/img34/...Hm_1a3d456.jpg The Turbo AWD: http://img26.picoodle.com/img/img26/...Lm_9fe0717.jpg http://img26.picoodle.com/img/img26/...sm_384ba7b.jpg (I know I know, guilty as charged, it's crazy to have two similar cars in the same colour :rolleyes: ) http://img82.imageshack.us/img82/369...elvm0011kt.gif At your service for any quest for more information on these streamlined cars :) . |
What happened to the video?
