EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Installed my mpguino - Civic VX (https://ecomodder.com/forum/showthread.php/installed-my-mpguino-civic-vx-29791.html)
slogfilet 08-20-2014 01:11 PM
1 Attachment(s)
Finally got it in! I used Posi-Taps to tap the VSS and injector wire near the ECU, then used the 12v constant and ground from my radio to provide power.
I considered myself a good mpg-er previously, but this adds a whole new level. It's very easy to see how some of my previous assumptions about engine load and speed were incorrect. For example, I can tell instantly when I drop out of lean burn and need to downshift on a slight hill.
While a good solder job is the best way to do it, I highly recommend Posi-Taps. They're secure, removable, and minimally intrusive.
I have it sitting in the hole where my clock delete plate was. Just need to make a little bracket, and possibly add a 4-pin Molex connector so I can take it out easily.
This is version 1.1 from Quezacotl... highly recommended. Shipping was fast and well packaged. He is now selling v1.2, which looks even better.
slogfilet 08-20-2014 01:13 PM
Note - I haven't calibrated it yet, but the default values on the Wiki seem to be pretty close. I'll dial it in on the next tank. I might have it slightly under report performance, so that I'm pleasantly surprised every time I fill up. Kinda like setting your clock 5 minutes fast so you're never late, ya know?
slogfilet 09-07-2014 11:46 PM
First full tank complete!
The bad news is that the injector signal is not calibrated. The vss is spot on, though!
Good news... it's actually under reporting. =) mpguino read 51.2 mpg, but actual fill revealed 54.4!
leety 11-19-2014 02:48 PM
Where can I get a mpguino I just got a 1992 VX and want to set this up. Also I guess a vacuums gauge too right?
Can you help me figure out how to do it please?
slogfilet 11-19-2014 03:28 PM
A vacuum gauge isn't required, but would be a helpful fuel economy tool. I'd like to install one soon!
Here's the guy I bought my mpguino from; he's also a member here:
MTH-Tek (User:Quezacotl)
Car related, MTH-Tek
Shipping: Worldwide
I'd be happy to walk you through the process! It's not too bad, really.
bluesteel93 11-19-2014 03:33 PM
MPGuino - EcoModder
Here's a link to the MPGuiono wiki that has lots of information including vendors that sell complete units. A vacuum gauge is helpful too and can be bought for fairly cheap from any autoparts store or from amazon. They are fairly simple to install too.
bluesteel93 11-19-2014 03:36 PM
http://ecomodder.com/forum/showthrea...x-14029-2.html
On the second page of this thread there is pretty much a step by step guide to installing an MPGuino in a VX.
leety 11-19-2014 11:34 PM
Thanks ya'll for the tips. Focusing on the differed maintenance and much needed repairs fist. Then onto the fun stuff.
leety 11-19-2014 11:36 PM
Yea the vacuum gauge prolly isn't that important, but I just like to measure stuff ;-) Just a little fun add on for my amusement really.
