Old 08-20-2014, 02:11 PM   #1 (permalink)
VX Padawan
VX du Slog - '94 Honda Civic VX
Installed my mpguino - Civic VX
Finally got it in! I used Posi-Taps to tap the VSS and injector wire near the ECU, then used the 12v constant and ground from my radio to provide power.
I considered myself a good mpg-er previously, but this adds a whole new level. It's very easy to see how some of my previous assumptions about engine load and speed were incorrect. For example, I can tell instantly when I drop out of lean burn and need to downshift on a slight hill.
While a good solder job is the best way to do it, I highly recommend Posi-Taps. They're secure, removable, and minimally intrusive.
I have it sitting in the hole where my clock delete plate was. Just need to make a little bracket, and possibly add a 4-pin Molex connector so I can take it out easily.
This is version 1.1 from Quezacotl... highly recommended. Shipping was fast and well packaged. He is now selling v1.2, which looks even better.
The Following 2 Users Say Thank You to slogfilet For This Useful Post:
Coreycolman (08-12-2015), leety (11-20-2014)
Old 08-20-2014, 02:13 PM   #2 (permalink)
VX Padawan
Note - I haven't calibrated it yet, but the default values on the Wiki seem to be pretty close. I'll dial it in on the next tank. I might have it slightly under report performance, so that I'm pleasantly surprised every time I fill up. Kinda like setting your clock 5 minutes fast so you're never late, ya know?
The Following User Says Thank You to slogfilet For This Useful Post:
leety (11-20-2014)
Old 09-08-2014, 12:46 AM   #3 (permalink)
VX Padawan
First full tank complete!
The bad news is that the injector signal is not calibrated. The vss is spot on, though!
Good news... it's actually under reporting. =) mpguino read 51.2 mpg, but actual fill revealed 54.4!
leety (11-20-2014)
Old 11-19-2014, 03:48 PM   #4 (permalink)
EcoModding Newbie Girl
Ecovox - '92 Honda Civic VX
90 day: 30.44 mpg (US)
The Dragon - '01 Dodge Ram 3500 Laramie SLT
Where can I get a mpguino I just got a 1992 VX and want to set this up. Also I guess a vacuums gauge too right?
Can you help me figure out how to do it please?
Old 11-19-2014, 04:28 PM   #5 (permalink)
VX Padawan
A vacuum gauge isn't required, but would be a helpful fuel economy tool. I'd like to install one soon!
Here's the guy I bought my mpguino from; he's also a member here:
MTH-Tek (User:Quezacotl)
Car related, MTH-Tek
Shipping: Worldwide
I'd be happy to walk you through the process! It's not too bad, really.
leety (11-20-2014)
Old 11-19-2014, 04:33 PM   #6 (permalink)
bluesteel93's Avatar
Turtle - '94 Honda Civic VX
90 day: 48.37 mpg (US)
SVO - '86 Ford Mustang SVO
Team Turbocharged!
90 day: 22.03 mpg (US)
MPGuino - EcoModder
Here's a link to the MPGuiono wiki that has lots of information including vendors that sell complete units. A vacuum gauge is helpful too and can be bought for fairly cheap from any autoparts store or from amazon. They are fairly simple to install too.
The Following User Says Thank You to bluesteel93 For This Useful Post:
leety (11-20-2014)
Old 11-19-2014, 04:36 PM   #7 (permalink)
Team Turbocharged!
http://ecomodder.com/forum/showthrea...x-14029-2.html
On the second page of this thread there is pretty much a step by step guide to installing an MPGuino in a VX.
The Following 2 Users Say Thank You to bluesteel93 For This Useful Post:
leety (11-20-2014), slogfilet (11-19-2014)
Old 11-20-2014, 12:34 AM   #8 (permalink)
Thanks ya'll for the tips. Focusing on the differed maintenance and much needed repairs fist. Then onto the fun stuff.
Old 11-20-2014, 12:36 AM   #9 (permalink)
Yea the vacuum gauge prolly isn't that important, but I just like to measure stuff ;-) Just a little fun add on for my amusement really.
