EcoModder.com
-   Saving@Home (https://ecomodder.com/forum/saving-home.html)
-   -   Insulative Paint (https://ecomodder.com/forum/showthread.php/insulative-paint-39975.html)
freebeard 01-31-2022 12:00 AM
Insulative Paint
I've been interested in cork paint for some time. These bare metal walls need at least a thermal break.
But the research I've done shows the established brands only sell to professional installers. It also shows the step by step instructions that the installers adhere to. :(
So what I'm wondering about is whether anyone has experience shredding cork for insulation. I know a source for wine bottle corks in bulk. It seems like the progression would be chopper > blender > flour sifter with the residue from the sifter going back to the blender.
That should produce cork dust I can add to a water-based interior enamel. I'd need the three implements, and then I could do some test mixtures.
redneck 01-31-2022 03:59 AM
For testing purposes.
Maybe use a food processor for the first reduction. Then use a coffee burr grinder to reduce further. The adjustability of conical burrs should allow for a consistent sized particle to be produced eliminating the need to use a sifter.
Wouldn’t a particle size larger than dust be more desirable ?
ME_Andy 01-31-2022 09:15 AM
Sounds like a good business opportunity if you can figure it out.
Same as Redneck- grinding the cork too small might not be a good idea since it's the air pockets that make for good insulation.
freebeard 01-31-2022 12:25 PM
Thanks. Blender and food processor are prolly the same thing.
I was wondering about a sifter with a coarser screen. I agree flour consistency is too fine. My coffee grinder is a miniature blender, I can look into burr grinders.
I just think cork would be better to work with than styrofoam.
Piotrsko 01-31-2022 02:38 PM
The only advantage to Styrofoam is it comes in pellet size if you want. Just add binder.
seifrob 01-31-2022 07:06 PM
I once tried the exact thing: to produce cork dust for our Kundts tube experiment. All experience in one word: it sucks.
Tried to process it in meat ?mincer?, in coffee grinder, everything I had at home. Best results were with sanding, but than the cork dust was contaminated with grains from sandpaper.
I was lucky enough to find a company making wine bottle corks and other cork stuff, and they gave me bag of cork dust. They were dumping it
freebeard 01-31-2022 08:17 PM
That's a data point. Cork dust is possibly less per gallon than the paint. I'd though of a meat grinder, but I guess not.
Looking on eBay, cork granules are used in boilie balls, whatever they are, by fishermen. 5 liters for $26. I guess I'll look for a brick and mortar fishing shop.
________________
According to the people who won't sell me their product, it's all in the surface prep. ;)
Piotrsko 02-01-2022 09:58 AM
Search carp bait. Carp are bottom feeders with a penchant for strawberries and need floating to help with the hooking therein using slider rigs.
If youre serious, there is cork underlayment that is rolled and about 1/8" thick. Sticky you have to do yourself
freebeard 02-01-2022 04:34 PM
I now have in hand the Rules, Regulations and Community Standards to which I am being held.* Fortunately I'm being grandfathered in.
Bare-metal aluminum is disallowed; one approved finish is stucco. So now I have to consider a cork spray rolled exterior finish. Maybe an epoxy enamel?
On the inside, I'd want a final coat of intumescent paint as well. So there would be savings there.
* Inspecting it for opportunity for malicious compliance. There is a gray area between a bleach bottle on a stake with flaps cut into it and a 'whomp, whomp' rotor.
Piotrsko 02-01-2022 04:53 PM
Some stucco finishes incorporate an acrylic binder instead of portland cement. Guy one block over has that, sprayed on just like paint.
