Interesting read about electric cars...
Bjorn Lomborg: Green Cars Have a Dirty Little Secret
Thanks for sharing this.
I have read reports like this before, but I fear they are biased. What, for instance, makes that the electric car is so energy consuming to make? Not the engine, that's way easier to make. Electronics, then? That would be the BMS boards and some extra computing components. Don't think that tips the scale. The batteries, obviously? Hard to say, so many types. One thing is sure: they will be recycled. Sure, the electricity has to be produced somehow and if that' s done by burning fossil fuel of any kind that means CO2 is being produced. But power plants are usually around or above 50% effective in generating electricity while the gas burning engine cannot get even half that. Some of the electricity gets lost in transport, conversion and battery storage, but I bet that is way less than half. But, gas needs to be produced too. It needs to be pumped out of the ground, shipped, refined, shipped again, redistributed, chemically tweaked to the right octane level and doped with all sorts of additives. The science magazine NWT ( Nature, Science, Technology, aimed at university graduates and the like) estimated that it takes 3 times as much energy to produce gas than can be derived from it. So there you go. Even if producing electricity produces CO2, producing gas is way more polluting even before it gets burned in the engine. That's no dirty little secret; it is the elephant in the room mr. Lomborg failed to notice. Why does he miss that? He is just an unbiased observer, right? All electricity is produced from coal, right? No bias, yeah. Maybe he missed that elephant because it blinded his eyes with a nice paycheck, or vouchers for free gas for life? Nobody pays me for writing this of course. |
We are now getting less than 40% of our electricity from coal, and it is going down every year.
Mr. Lomborg is hardly unbiased, so unless he backs up claims (like how an electric car supposedly takes more carbon to build), then he's just talkin'. Gasoline takes electricity to produce; from discovery of the oil, to drilling to extracting, and transport, storage and/or pipeline pumping, refinement, and even pumping it into your tank - and all that electricity and it's carbon footprint have to be counted in the gasoline. Also, there is a lot of natural gas and a lot of water used to extract oil and to refine it, and the entire energy overhead for the natural gas and water uses electricity, and that has to get added, as well. The most important point is that electricity *can* come from renewable sources, and over time more and more of it is coming from renewable resources. So, oil gets dirtier and dirtier over time (sour crude and tar sands bitumen and deep water drilling and fracking) - electricity will get cleaner and cleaner over time. |
It currently takes the energy equivalent of 1 barrel of oil to extract 20 barrels of oil from the ground, and deliver it to the refinery. If we assume that a barrel of oil is worth 1.7 MW-h, it would take about 85 kW-h to do that extraction. At this point, we're assuming that a barrel of oil is worth (1.7 MW-h - 85 kW-h), or about 1.615 MW-h. Okay, so far, so good. Now, let's take refining costs. It Let's say that it takes about 140 kW-h to turn that 42-gallon barrel of crude oil into about 45 gallons of useful things. So, taking 140 kW-h away from out 1.615 MW-h value, and we're left with 1.475 MW-h worth of available energy from that barrel of oil. Now, gasoline accounts for roughly 47% of that barrel by volume. That means that there is about 21 gallons of gasoline produced (remember, we just spent 140 kW-h refining that barrel of oil). Also, 45 gallons of usable stuff are produced from that barrel. If we divide the remaining available energy content of what we have, by the number of gallons, we come up with about 32.8 kW-h of available energy per gallon. It's weird, I know, but it matches rather well with the fact that gasoline is commonly thought of as being about 33 kW-h of energy per gallon. Now, let's go nuts, and say that gasoline production accounted for all 140 kW-h of the energy spent refining that barrel of oil, and that all other petroleum products from that barrel came scot-free! Okay, then, it would have taken 6.6 kW-h of energy to produce one gallon of gasoline. Since, in the absolute (and unrealistic) worst-case scenario, it took about 6.6 kW-h to produce something that has a value of 33 kW-h. Even if we then throw away 80% of the energy value of gasoline, in the form of radiator waste heat, exhaust, mechanical losses, blah-blah-blah, that still leaves 6.7 kW-h left per gallon that actually does something. Sounds like this "NWT" is a fiction magazine... Quote:
Just charge an EV owner 45 bucks at registration to cover the offset, problem solved. :thumbup:
Right, that 6.6kWh would let a 2013 Leaf drive at least 23 miles, which is the same as an average car goes on a gallon of gasoline. So that means it takes just as much electricity to drive a gasoline car as it does an EV.
And *none* of the other carbon in the gasoline, or in the natural gas, etc. used to get the gasoline would be released into the atmosphere. |
But I strongly disagree about the claim that it takes just one barrel to produce twenty. That's not taking the effort in account to build the installations that get the oil out, fly in the personnel, etc. Here on the North Sea there are several known oil deposits, but some won't get exploited because the oil price is just too low right now. It is too costly even at current oil prices. It wouldn't be if it took just 1 barrel for 20. Maths are nice, but you can get any numbers depending on what you count in or out. The NWT's sources had done a full involvement (or whatever it translates to) study, including all activities needed to make the process possible and their support structure. You need to build a refinery, operate it, build roads, supply chains, etc. Sorry that you don't like NWT's conclusions. I assure you they do a scientifical approach. But I recite from memory. Maybe, I give you that, they meant that it takes 3 times as much power to produce gas than can derived from it by the cars engine meaning that the chemical energy in gas is still somewhat higher than the energy wasted in production. But even if they meant that it still derails the dirty little secret argument. It is just not true. |
The carbon footprint of oil is a very complicated thing to know precisely. We do know it takes a lot of electricity, and a lot of natural gas, and in at least two methods in use right now, it also takes an immense amount of water. All of these have their own overhead energy, and natural gas itself uses a lot of water and a lot of energy to frack.
To just get some crude out of the ground, they have to make steam and inject that underground to just soften the crude up enough so they can manage to pump it out of the ground. Tar sands bitumen has to be "washed" out of the sand with millions of gallons of heated water - and *then* it has to be dissolved in cheap gasoline (which had to be made!) so that it has a chance of being pumped through a pipeline. Pumping overcooked oatmeal would be easier... Nissan said that it takes ~7.5kWh of electricity per gallon of gasoline. Other estimates put it about there or slightly higher. And yes, the carbon footprint of electricity (which is about 38% from coal in the US) has to be done from source to plug. But this same overhead also goes into the gasoline - so when you are comparing electricity to gasoline, it cancels out because it is on both sides of the equation, and you are left with the rest of the embedded carbon in the gasoline. It takes as much (or more) electricity to drive a gasoline car a mile as it does to drive an EV a mile. You can drive an EV for 2-3˘/mile including electricity and regular maintenance. A typical 23MPG car costs ~15˘/mile for gasoline alone, and another 3-3.5˘/mile for regular maintenance. So, a ICE car costs about as much to maintain (at typical dealer service charges) as it takes to drive an EV - and you save all of the money you would pay for gasoline. A 40MPG car with $3.50/gallon gas will cost you $8,750 to drive 100K miles. Drive an EV and none of that 2,500 gallons of gasoline gets burned, and you pay $3,480 (290Wh/mile @ 12˘/kWh) to your electric company instead of your car dealer. If you ecodrive the EV, you can likely cut that by ~25-30%. |
There is no getting around the law of physics. :thumbup:
:):):) JJ |
The underlying numbers used in the analysis for the WSJ article may be completely offbase i.e. wrong.
The LlewBlog - Electric Cars - The Truth Will Out. If the original study based their calculations on a 1,000kg electric motor and a Leaf actually has a 53kg motor - then that pretty much negates the entire article! |
Neil,
I have long since gotten sick over any news report or article that starts out with the words: "A new study has found that........." It is always followed by some titillating story that hardly ever mentions the source of the 'study'. And if they do, it is some University somewhere. You know, written by people who need to complete their thesis so they can get the hell out of there. People with absolutely NO real world experience. I am not surprised about the 'errors' found in their report. Give them a D- and let them study under their slave-driver advisors another semester or two. Eric |
Don't bother for the student thesises.
What we see here is involvement from influential players in the power market. It goes too far to call it a Big Oil Conspiracy by my taste, but sure those companies (like I guess any big company would) do a fair bit of lobbying for their causes, and don't shy from influencing public opinion by supporting publications that may unwittingly or otherwise bend the truth in their favor. How are we to know what to believe? I fear the only way is to dive in, find contrasting data and opinions and evaluate what's happening there. |
See the second post by Vike in this thread for a levelheaded assessment of the WSJ article:
Mitsubishi I-Miev Forum • View topic - Are Journalists Trying to Kill the Electric Car? Another dissection of Mr. Lomborg's erroneous article: http://switchboard.nrdc.org/blogs/mb...p-ed_need.html |
Likely written to by someone with no experience with electric vehicles either...
Dr. Lomborg's positions are among the most pragmatic and rational that I have heard between the two extreme environmental religions (humans will permanently destroy the environment / humans cause no environmental harm). How can Lomborg be considered biased? He used to be one of the extreme environmentalists, and he is convinced human activity has increased global CO2 emissions and temperatures. What facts in the article are we disagreeing with?
It usually follows that something that costs more also consumes more resources. An electric car costs more money and consumes more resources initially. This most salient point is expressed at the conclusion of Lomborg's article: Quote:
What is most appalling is that almost nobody bats an eye at the fact that the US government steals $7,500 from tax payers (that's me and you) every time an electric vehicle is sold. How can a person (Obama) or even a huge group of people justify the forceful redistribution of money from an individual to another individual that happens to want to purchase a particular type of vehicle? I could understand how some might violently oppose this theft. Cut subsidies for oil companies, agriculture (ethanol), and electric vehicle manufacturers and let the consumer bear the real cost. Electric cars, renewable energy, and "sustainable practices" are an inevitable outcome for a species that looks forward to the future, not the outcome of saviors from Washington DC. That said, I am seriously considering the purchase of a new Nissan Leaf, assuming the long-term financial math works to its favor. If I could vote against the insane federal subsidy, I would. Since it's already here, I will take advantage of the credit. Check out the trailer for a favorite documentary of mine called Cool It. If you really want to attack Lomborg's credibility, you will want to learn what his major arguments are. Argument |
I don't bat an eye at electric subsidy because oil and others have had so much subsidy for so long, the playing field is not even close to being level.
The price of oil is subject to demand. EV's reduce that demand and thereby running costs for non-EV's.
Oil is mostly imported, so reducing both quantity and price will have a big effect on the import/export balance. Powerstations usually use local sources. Who do you like to spend your money on? |
The Tesla S may be a flash in the pan, or it may be the signpost showing industry the way forward. But there can be no doubt that it is a brilliant accomplishment and a tremendous piece of automotive engineering and art. I for one have no problems with a couple of my tax dollars going into its creation; in fact I feel a good bit of pride in it, and in the fact that Tesla is a US company. We need more like it.
The problem will be that, should we actually ever stop whining and get back to work in this country, we'll have to very quickly remember the ratio between startup successes and failures. I used to work in R&D and I now work in a highly competitive segment of the communications industry. I can tell you from experience that there are a lot more failures than successes. In my opinion the federal government should subsidize industries that aren't quite there yet, or that hold great promise but do not attract sufficient private investment to get them moving. If the feds didn't back some losers I'd be astonished. If/when electric cars become ubiquitous, and they all come from, say, Brazil, how many people do you think would be moaning about "the US falling behind once more"? I'd be okay with the Tesla S being so successful that it spawns a host of would-be imitators. I'd be fine with one of them building a more affordable 200 mile all-electric car. I would not mind seeing my tax dollars go to Wawa (a local convenience store chain) to give them incentive to put in charging stations. In 10 years I could be driving gasoline powered cars just in parades on holidays. That would be fine with me. |
Electrification in the US began in the 1880s, a good 2 decades before the Ford Model T. The first automobiles were electric. The US had many electrification projects and subsidies to grow power production and distribution. How many people have a gasoline pump at their house? Nearly everyone has an electric outlet. Electric vehicles have had every opportunity to be the dominant transportation choice in the US, but they simply could not compete with the energy density of petroleum. They still cannot compete with the energy density of petroleum. Who wants to pay twice as much for a vehicle that travels 1/5 as far and cannot be fueled up in 5min? I do, but I'm a minority, and a multiple vehicle owner. Quote:
If a person forced me to be a venture capitalist with no direct ownership in a company that would be criminal. For a government to force me to be a venture capitalist with no personal benefit from success is tyrannical. The government should have no business in venture capitalism because politicians don't have the motivation or expertise to make efficient decisions about how best to allocate R&D funds. The logic just does not follow. If government is the best way to develop a technology, then they should be called upon to develop the next iPad, or make my TV screen thinner and larger. Incentives to develop alternative fuels and vehicles already exists because consumers demand better, faster, cheaper, longer, greener. Quote:
Why are food prices skyrocketing? The government subsidizes farming, and in particular corn crops. If we weren't forced to burn 10% ethanol in our vehicles the crops could be used to feed people. A case for subsidy might hold up for really big projects, such as the development of fusion power. There may be a place for government in the sciences, but certainly not in industry and the marketplace. It really cannot help in those areas, and it's unfair. |
The Surprising Reason That Oil Subsidies Persist: Even Liberals Love Them - Forbes
Supprising at what counts as a "oil company subsidy" when one wants to throw arround numbers. from Energy subsidies - Wikipedia, the free encyclopedia Quote:
Looking back at the posts you can see a clear distinction between the pro and con posters based on what they drive.
No blame here, cannot expect anyone to preach outside their own church. Like companys we fend our own demands. Nobody's unbiased though. My stand: I am pro electric but I won't drive an electric car. Even though the range is ten times better than a century ago, it still falls back to a gas driven car. It should be no problem as I can charge it every night at home or wherever I go. That's not my reason. The ride quality is superior and fuel price is too, certainly not my reason to not go electric. I'd love that. Just like its reliability; basically it is so much simpler than an ICE. I simply cannot afford an electric car (*) The Nissan Leaf and the Mitsubishi i-Miev are basically subcompact cars, but they are at least twice as expensive as comparable cars with an ICE. I cannot make up for the difference even if electricity were entirely free. As I expect the batterys to expire before I'd driven the same distance that I could on the ICE comparison on the fuel I could buy for the price difference. So with pain in my heart I have to keep burning gas until the batteries used in EV's get twice as cheap, twice as powerful or twice as long-lived. The break even point is nearly there. It just isn't yet, or it needs to be subsidized even more than it is today. I don't mind those subsidies; it prevents sending money abroad for oil. And it sure is cleaner; I'm convinced of that even more than before by comparing all the data above. But I have a mortgage to deal with, growing kids etc. Scientists and lobbyists and sensation-seeking journalists can argue whatever they want. Wallet wise EVs still are wallet unwise. You need a green heart and a lot of green paper to run them. I ecomod my car and driving habits and save money instead of spending it. Driving less and doing so more economically benefits the environment beyond any doubt. (*) Oh I'd love to aquire a disused forklift or such and experiment away with it in all my free time. If I had that. While I wrote this the telly aired another Nissan Leaf commercial. Maybe that's the clue. It is cheap to make, but the ads add up. If only they could skip those and make it cheap, and less than plain bone ugly...? |
You can only make it in the eco market by investing your own money. Subsidies are just additional. And hey, I pay tax. Lots of it. 21% VAT on anything I buy. 40% additional tax (or abouts) on gas; see my post footer. Over 30% income tax, road tax, insurance tax, home ownership tax, water management tax, something I forgot about tax, you name it. It is my money too. And my planet. Would you forbid me to say I do not mind subsidies are being given for environmental friendly technology? On this forum? :D |
Mr. Lomborg's article is not standing up to scrutiny:
Wall Street Journal Op-Ed: Electric Cars Dirtier than Gas Cars | PluginCars.com Electric cars are cleaner than any other energy source, and they can get cleaner and cleaner over time. |
Pure-electric cars are still too expensive for the average Joe, and also their range is a matter of concernment. It's perfectly understandable, since many folks can't afford to buy a pure-electric for city commuting and get a longer-range vehicle for occasional road trips.
Most- by that I mean most every- households are multi-vehicle.
439 passenger cars per 1,000 people in the US, according to this article : It's Official: Western Europeans Have More Cars Per Person Than Americans - Max Fisher - The Atlantic
http://www1.eere.energy.gov/vehicles...0_fotw618.html
2009: 1.92 vehicles/household; 1.52 vehicles/worker http://www.autospies.com/news/Study-...usehold-26437/ This one says 2.28 vehicles/household... |
Each report slices different data differently;
How is it relevant? I would say that the (cell phone reachable only) young people will buy cars later (than we did when we were young) and when they do, it will need to meet all their (long or short distance traveling) needs. |
Do you think the Nissan Leaf would not have been developed without the US $7500 subsidy? It likely would still have been developed, and even if it wasn't that just means it doesn't make economic sense at the moment. Quote:
A major point of disagreement is often a difference in philosophy, which is why politics and philosophy are a natural topic of discussion here. For example, the answer to the question of who owns the fruits of ones labor will shape the answer to the question of what ought to be subsidized and how much. |
Subsidies for eco-friendly technology - good or bad?
It takes visionaries like Edison to break the cost/profit curfew on new technology. When Edison promoted electricity for home lighting he insisted that the light bulbs he sold should never cost more than 40 cents, even though it cost him $1.20 to make them. Because he knew that at $1.20 per lamp most households would just stick to their trusty oil lamps. He expected, rightly so, that in time with large numbers the cost per lamp would eventually drop below 40 cents. The rest is history; we don't use oil lamps any more. We still use oil cars, though. Not many entrepreneurs have the balls to take risks like Edison did nowadays I fear, unless they are really rich and determined to do something good with that. So what should a government do, concerned about pollution and such? Pass a law to forbid or curtail ICE powered cars? Or subsidize cars that don't use ICE's? Or just do nothing, ignoring the problem? I don't like them sitting around doing nothing. I don't like them putting fences to prohibit people from using their cars in the way that fits them best. What rests is to stimulate the good cause by putting money in, a fraction of all the taxes we pay. I think the government cannot function if it cannot exert its power bestowed on it by us though democratic means. Subsidies are a benign way of nudging those involved towards the wanted goal. (*) Recently Honda came under fire because the batteries in the Honda Civic Hybrid from model year 2009 onwards frequently failed, often just outside the warranty limits. So they extended the warranty limits for both duration and mileage, even though that will just increase their loss. |
EDTA: Wall Street Journal attacked plug-in vehicles with "fuzzy math"
Passenger vehicles in the United States - Wikipedia, the free encyclopedia
