EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Interesting read on pickup truck aerodynamics. (https://ecomodder.com/forum/showthread.php/interesting-read-pickup-truck-aerodynamics-15640.html)
bondo 01-01-2011 08:56 AM
It seems the geometry of a truck bed has a great effect on the Cd of the pickup truck. This research paper presents some interesting wind tunnel data and explains why later model pickup trucks have such high side walls and tailgates.
It seems the manufacturers have sacrificed the utilitarian aspects of earlier model pickups (with low side walls and tailgates) for the taller bed height we see on the late model pickup trucks, especially those trucks with the shorter beds. It's all about reducing the Cd of the pickup truck to improve the fuel efficiency of the truck.
http://www.wseas.us/e-library/confer.../FMA/FMA17.pdf
Happy New Year and may 2011 be a good one for us all.
Bondo
JasonG 01-01-2011 09:35 AM
Interesting.
Makes sense though. Same principle of why wagons and stretch limos get better FE.
Apparently flow reattachment over length is more important than I thought it was.
t vago 01-01-2011 12:27 PM
Originally Posted by JasonG (Post 212335)
Interesting.
That would explain why all of those late model pickup trucks have such high beds. They're almost like open-topped versions of the traditional van body.
cfg83 01-01-2011 02:07 PM
bondo -
Great find! Do you think that this stuff like this could be a missing detail in the "tailgate up/down" theory? That is, it depends on the length of your bed (the geometry!) :
http://ecomodder.com/forum/member-cf...eamline-03.jpg
What do you think?
CarloSW2
blade 01-01-2011 02:09 PM
yea i guess that makes sense after i think about it
Piwoslaw 01-01-2011 02:18 PM
Thx Bondo and cfg83.
I thought the high bed walls were for a more massive/macho look.
Ryland 01-01-2011 03:21 PM
That does not explain why the body is jacked up and why the frontal area of a truck is so big! even the little Toyota trucks are a half ton truck, just like F-150's and Toyota made a 1 ton truck that wasn't much bigger then their half ton truck.
That paper seems to agree with the van shape but the big problem with trucks is that you need a step ladder to get in to the truck bed.
bondo 01-01-2011 04:43 PM
Originally Posted by cfg83 (Post 212370)
bondo -
What do you think?
CarloSW2
It may very well be. You have now attached a theory to a theory but it does make sense. Your graphic does a very nice job of explaining your thought.
That is definitely thinking oustside of the box!
Bondo
Big Dave 01-01-2011 10:23 PM
This would militate toward the sloped sidewalls of the GM Avalanche.
Frank Lee 01-02-2011 05:06 PM
I suspect they did not get high for aero; they are high because of the ginormous wheel/tire packages driving the entire chassis up. The cabs are higher too.
