Interior mirrors...
Pilot Automotive makes what they call the Ultimate Adjustable Blind Spot Mirror, part number MI-142Z. It's not listed on their website and I've only found it at AutoZone for $11.99. I've found it on eBay fer about $20 shipped from other sellers. It's designed to stick to your windshield with 3M tape and can be adjusted up/down about 4", swivel, mirror is offset so you can flip it over,and the arm can be raised/lowered as well. The mirror is made from glass instead of plastic and should hold up to fine scratches that plague the plastic ones. :D
Link... http://www.autozone.com/exterior/bli...or/257122_0_0/ I've pulled my previous blind spot mirror out and replaced it with the Pilot Automotive one after I took it apart and hard mounted it to the A pillar trim. http://i677.photobucket.com/albums/v...pshhu7gbdw.jpg |
I've been trying to find out who I got the idea from on here. I remembered that someone was modifying them in some way. Thanks for the update!. I was just thinking of getting another set just in case they stopped selling them. I got them at autozone too. They are much better than my stock side mirrors for reducing nighttime glare from the newer oem ultra bright headlights that feel like they're on highbeam aimed at my retinas:cool: I can see much better around the driver's side as well. I use the passenger's sideview pilot mirror in combo with the rearview spot mirror to see along the passenger side better too.
Here's my current layout. You can see that I haven't replaced the left mirror yet. ;)
http://i677.photobucket.com/albums/v...psghnauuts.jpg http://i677.photobucket.com/albums/v...psuydn1qzy.jpg |
Now that's an interior setup:thumbup: Teslas got nothing on the touchscreen acreage there!
how well do they work at night? can you take off the outside mirrors now? I know its a pickup with a trailer. and you need good mirrors.But for a car? I was just about to buy some $5 3" plastic round mirrors as I will need them when my boat tail is complete. I should spend a little more if they are worth the cash..
I like the fact that these mirrors are glass. I had some serious issues with scratches building up on the plastic lenses. The previous mirrors I had aren't made any more so this was my next progression. I have noticed that the angle isn't as wide as my previous version but hopefully I'll be able to adapt quickly to the new ones. I never liked the blind spot mirrors on the outside...especially during inclement weather like rain/mist/snow/sleet/ice/fog as both the window and the mirror gits moisture on the surfaces making it near to impossible to see the mirror's reflective surface cleanly. The interior mirror doesn't suffer from that issue as there is only one surface (window) that can affect its performance and on my truck, my vent visors provides a clear spot where the blind spot mirror can usually see cleanly through. ;) My interior mirrors were never meant to replace the outside mirrors as they can never git the direct rear view along the side of the truck that I need when backing up. The blind spot mirrors can't git that angle as they are inside the vehicle. I won't be removing my outside mirrors anytime soon. However, I will try a small blind spot mirror that I can mount on the edge of the mirror so I can see when the mirror is folded in...but I think that real estate will win out. :D |
Is the image on the small mirrors large enough to see well?
I need 1 outside mirror for MD law. I disobeyed the law before :eek: and took them both off. I hated it. I was nervous all the time and put it back on the next day. I don't need both sides just the drivers side. If traffic were slower I would be fine I'm going the speed limit everyone else is going 20-30MPH higher.
I was thinking about using this for the outside mirror as it looks to be about half the size of the stock one. http://ecx.images-amazon.com/images/I/41ywixCVrTL.jpg "only use the top part outside" And two more interior mirrors. now you show me these I am second guessing myself! |
I have the mirrors on both sides and I like them more than the OEMs. The nighttime visibility was a pleasant surprise I didn't anticipate with respect to high intensity light. I have very good vision so if you have problems see far I can't speak to the results you would have with them. I have a bigger problem with placement since the A pillars are an interferance. I understand why BAMzipPow wanted to mount the passenger one on the pillar instead of the windshield. It gets it closer to the side glass and around the pillar. If I follow his path I may not even need the spot mirror on the rearview for the cars further behind me. I'm extremely pleased with the one on the driver's side. Its plenty big there. |
Awesome thanks buddy!
No issues with glare last night. Still trying to git used to the smaller angle of view. I'll try to mount the driver's side today and see how that goes. ;)
As far as image size goes, the passenger side one is large enough to see with fer my needs. I'm sure the driver's side one will work equally as well. :D |
Nice! thanks man. Id rather spend $20 and get something good then buy a cheap set only to end up buying the more expensive set down the road! My eyes suck at night time and glare is the main killer for me! I'm glad they work good. Thanks again guys!
All done! I mounted the mirror off of my Panavise mount fer my GPS. ;)
http://i677.photobucket.com/albums/v...ps5zkx0nfb.jpg |
Trying out mirrors on the edge of my folded mirror to see how that will work. ;)
http://i677.photobucket.com/albums/v...pshinejcb0.jpg |
Hopefully you don't have airbags deploying from the A-pillar. That's a lot of hardware to come flying back at 100 mph. :(
With the driver's mirror folded in, I can easily see along side of my truck and to the left just fine without any issues so far. I was able to back up and see the curb line this afternoon at the school. :D
I'll have to try a set on the passenger side but I think those mirrors will be too small to see any significant amount of details...but I won't know until I try, right? ;) |
Could you please expound upon how you mounted the passenger side interior mirror? Does it come with the mounting bracket?
It comes with an adjustable plastic angle iron bracket with two sided tape on one facet of the bracket and the punch out holes for locking the sliding adjustment for the mirror arm on the other facet. BAMzipPow just removed the adjustable mounting to mount the arm directlyon the A-pillar.
https://scontent-b-ord.xx.fbcdn.net/...99&oe=5522817F https://fbcdn-sphotos-h-a.akamaihd.n...53081668846a63 |
Nobody really answered this, but could you remove your outside sideview mirrors and replace them with these on the inside?
https://fbcdn-sphotos-d-a.akamaihd.n...4dfa42dc480142 Quote:
replace
You need to know your driving environment at all times.Saving fuel isn't worth your property,that of others,and health/life. |
"Situational awareness"
Now that I see the responses, I'll take that as a no. |
By law here I need one outside mirror.
I have removed my passenger side mirror a week after I got my car and never missed it. I can just turn my head around and look. You cant do that with a pickup and a trailer. I removed my drivers side mirror and couldn't see good enough to be considered safe.(regardless of the law) I am working (slowly) on a boat tail and will sacrifice rear vision for better Aero. I need to replace the rear vision I am losing. I am going to get that smaller outside mirror I posted a picture of in this thread, put it outside on the drivers side and get these good interior mirrors. Hopefully that will be enough. If not I will add more interior mirrors. If that isn't good enough I will add an outside mirror to the passenger side. (both equal about the same frontal area of one stock mirror) If that isn't good enough I will get a camera system. |
Driver's mirror folded in...
http://i677.photobucket.com/albums/v...psn6hx7mkd.jpg Passenger's mirror folded in... http://i677.photobucket.com/albums/v...psoovbsr9t.jpg Edge mirrors on the driver's folded mirror... http://i677.photobucket.com/albums/v...psih2zkqbw.jpg Clip-on mirror on the passenger's folded mirror... http://i677.photobucket.com/albums/v...pshivwvwzf.jpg Interior view of the clip-on mirror... http://i677.photobucket.com/albums/v...pspktklvaw.jpg I'll only be folding in the mirrors when I'm doing long drives and clipping on the clip-on mirror at that time. During my local runs, the both exterior mirrors will be folded out to their normal positions. I'm not sure how well the small mirrors will do in inclement weather but I will guess they won't be of much help and I'll have to fold my mirrors back out. ;) |
I see you took the same path as I did... :D
I didn't like how the vertical mirror turned out on mine so that's why I went horizontal. I may add another mirror on top of that giving me 3 mirrors on the edge of the folded driver's mirror. ;) |
Haha yeah the vertical mirror ended up being kind worthless. I was thinking about adding a 2nd matching interior mirror on the passenger side at the other screw slot. I think that would give me adequate vision without the extrior mirror on most ocassions.
I would really try a mirror on the outside as you need that angle to see along the side of the truck. ;)
I'm going to be experimenting with printed cases for Raspberry Pi cameras (which are quite small) for my next daily and race car instead of using mirrors altogether.
I've been testing a Pi (Model B) long term as a media server and have had zero issues with it being run for more than 12 hours a day every day for the past few years, so I'm not really worried about that aspect of it; it's the little HDMI 7" monitors I bought from Ebay that have had issues, but I'm sure I can figure another way around that before long. Image quality is quite good (https://vimeo.com/68099584), plus you can view live on the monitor AND save the capture to a raw h.264 file (making it small) in real time; I intend on having 4 of these going and feeding a carputer with data when the time comes. Have you considered this as an option? |
2 Attachment(s)
Nice job!:thumbup:
Here is the thread of mine that I did 3 years ago with Pilot Automotive mirrors. I also took off my mirrors.:cool: http://ecomodder.com/forum/showthread.php/easy-mirror-delete-mod-20871.html Pilot Automotive have different shape mirrors. So far I've seen the ones you have, circular shaped (currently have installed), and rectangle shaped mirrors (currently have but not installed). |
I have fooled with interior mirrors and haven't had much luck with them. They are usually too small and too curved. The best interior setup I have used has been the old, superwide Wink mirrors. Ugly as Hell but panoramic view of the rear and sides.
