EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   iPod as hypermiling tool? (https://ecomodder.com/forum/showthread.php/ipod-hypermiling-tool-5921.html)
NiHaoMike 11-08-2008 07:25 PM
Has anyone thought about using an iPod as a hypermiling tool? Some of us already own one and a used one (particularly a small one) is pretty cheap for those who don't. Then add a PIC to translate between the OBD signals and the serial bus signals of the iPod and write a program to enable the iPod to use the interface. There'll also be some nice audio I/O hardware for voice guided hypermiling and several gigabytes of nonvolatile memory for storing logs. And with the proper programming, it can play music at the same time. I remember reading that an iPod has the processing power of an early Pentium PC (more if video capable) so there should be no problem as far as CPU is concerned.
SVOboy 11-08-2008 08:12 PM
There are some tools out there already: Saving Gas with the iPhone Gets a Bit More Sophisticated | Hypermiling, Fuel Economy, and EcoModding News - EcoModder.com
The Atomic Ass 11-08-2008 08:27 PM
I don't think that's an interface setup there, just graphs based on known static numbers, + incline changes as recorded, perhaps in real time?
Still, it should certainly be possible, but nobody sees the market for it, probably.
Autotap for example, great hardware, but only lack-luster Windows software. No Mac software, no Linux, no nothing but Windows. :(
NiHaoMike 11-08-2008 08:41 PM
Look like time to make one with all hardware plans and source code under GPL...
tangomar 11-11-2008 02:23 AM
This guy is developing an application that will run on Iphone, Blackberry, ...
I hoped he could endorse also generic Java Cellphone (like mine) but no plans (for now).
JDash Mobile - JDash
