Isn't it more efficient coasting in gear/engine on?
From what I understand, Almost all modern car engines shut off the injectors when the engine is down revving, foot off the gas in gear.
Sure, I won't coast as far a the proponents on here who coast in neutral, engine off...which is very dangerous, and in most jurisdictions, very illegal. Even coasting in neutral with the engine idling will waste more gas than engine even braking, as is see it. Thoughts? |
1. topic is addressed in other threads.
2. 'all modern engines??????? 1984 and up? 1999 and up? 3. Majority of posters here have 'older' cars. 4. the issue of engine on/ neutral coasting has been determined to be manufacturer specific. Alos addressed in other threads. for example, the last year of the ford taurus (mayby older ones also) DOES NOT gain any advantages. the rpms DO NOT drop My 02 (02-06) Infiniti Q45 DOES benefit from engine on/ nuetral coasting DOES make a difference. |
My car at 40 MPH, in neutral: ~245 MPG
My car at 40 MPH, engine braking (3rd gear) ~130 MPG Conclusion: The Toyota Yaris manual transmission DOES NOT DFCO. Approximately twice as many MPG's in neutral. Cheers. |
If your car can handle it, and it is legal where you are and you are in full control engine-off wins - the Prius turns the engine off when it can. You also need to know your car - for example in my Aygo it won't go into fuel shut off mode unless the engine rpm is over ~1400. In a low gear this results in a lot of engine braking, in a high gear less. So as I tapped it depends - on the scenario, your car and what you feel comfortable with. Quote:
With deceleration fuel cut-off (aka engine braking) you have no fuel used but the engine is slowing the car down a lot faster than in engine-on neutral coasting, where you have the engine idling but not slowing the car down.
DFCO will obviously save fuel if you were slowing down anyway. |
Even if your engine has DFCO, it is still losing some energy from friction (pistons going up & down, &c) and from pumping losses, so obviously it is not more efficient.
The danger/illegality issues have been addressed elsewhere, so I'll just point out that what you believe - coasting is unsafe, big SUVs are safer than small cars, all your kids are above average - may not match reality :-) |
I've been doing that all my driving life, and it give fairly good mileage. But if you want to do better than fairly good, you'll also need to drive differently ... Quote:
They exist from days when brakes were nearly useless and unreliable, so engine braking was almost mandatory to slow down. Quote:
Coasting with the engine on instead of engine braking is what has helped bring down my fuel consumption from already "fairly good" ;) |
