It's all about compromise - a study on front bumper design?
Many of you may have seen my new Off-Road Prius build that's in the works (if not there's a link in my signature).
One major component I would like to upgrade is the front bumper. Obviously the factory bumper is fairly good for aero and can be improved with a simple grille block and (more) flat floorpan, however it does not give the best approach angle for off road abuse nor is it strong enough for highway animal strikes. This is where my study begins, how much compromise do I need to have to get my perfect bumper? Where are big advantages available in one area that detracts least from the other area? The end product will most likely end up somewhere in the vast range between this: https://encrypted-tbn0.gstatic.com/i...yvwnK&usqp=CAU And this: https://encrypted-tbn0.gstatic.com/i...a3S67&usqp=CAU And here's the car in its current guise: https://attachments.priuschat.com/at...100816205.jpeg Grill block and flat floor can both be combined with a metal bash plate which will likely extend all the way from the factory numberplate position all the way to the tail end of the diffuser, but other than that I'm open to front shape suggestions. |
Just to summarise what we've already communicated:
1. Height-adjustable air suspension will give you off-road clearance but also allow a good ride height for low drag on made roads. 2. Gaining a good approach angle would normally mean lifting the leading underside edge of the bumper. This is not good for drag or lift. As I think you said, best to have a removable section to change approach angle as required. 3. A full-length bash plate should be good for both low drag and off-road protection. But keep it wide and smooth. |
So maybe what you're willing to do is shape the reinforced bumper closer to the shape of the bow of a boat.
This panel will act as a grill block (probably with movable louvres for Australian summer) and the front section of the bash plate, protecting the radiator. And could have a quick release front lip/air dam on the bottom of it. The tricky part then comes on each side where the body curves around to meet the wheels, how much clearance will I need in front of each wheel vs how much air dam can I fit in front of each wheel? If I remove the factory air intake box there is basically nothing outside of the chassis rails so I can bring the nose in quite narrow from the wheels to the radiator bash plate. There's also the possibility of cutting off the outer wings on the factory bumper and using them with some quick release clips to have removable air dams in front of each wheel? |
No one will be able to say what the results will be without testing of various iterations.
All else is just speculation - 'pissing in the wind', as we'd say here in Australia. |
Unfortunately I'm still waiting on an OBD2 reader to come from China and assist with "before" measurements, I'm quite interested to see what difference just taking the whole bumper completely off makes.
