Jeep Grille Blockoffs
So I had a significant increase in fuel mileage from 15 to 20mpg in my 2000 Jeep Wrangler. This last tank was on roughly the same split of highway/country/city roads I do every day. The ONLY thing I did different as an experiment was block off 4 of the 7 grill inserts with tape to try and raise the temp since it struggles to get to temp quickly even in the summer with a 195* thermostat. I did not see much change in engine coolant temps except at highway speeds it did get a but hotter, but still at a very safe temp.
Stock sized 31” AT tires and just a .75” lift up front and a 5.3 LS with headers. Also added a bug deflector which really took the wind rush down a lot so I assume it routes air over the flat windshield pretty well. Before this even if I tried really hard for mpgs, I would maybe get 16.5mpg. I went and checked that I filled up all the way and mapped out my drives on this tank to verify the numbers were correct, and they were. So has anyone seen such an increase with something like this alone on a brick like vehicle? |
An increase of 33% seems unlikely.
Maybe an A-B-A test? |
I’d like to try it on my 1990 F150; also a brick shaped vehicle, and I typically get about 12mpg, and 14 on the highway. It’s pretty miserable, so I’d like to see how it goes. Would probably just block off the radiator side the AC is on and keep the radiator side open. Worth noting that the truck still has an engine driven cooling fan.
Yeah I don’t think I’d go crazy and limit the air going to the radiator. Maybe a half block off for the winter, but not during the summer. We get 90+ degree days here regularly.
Just remember that factory grill openings and radiators are sized for 100 degree days with high humidity while sitting in bumper to bumper freeway traffic. There is a lot to gain aerodynamically for someone that is paying attention. You can probably block at least half the grill if you are aware of the operating temps.
aero mods and mpg
On my CRX, there was a natural variability of between 36-mpg, and 82-mpg, depending on 'routes' and 'weather', and this was without any changes to the car after modifying.
Just shooting from the hip, even if you completely blocked off the radiator, it's unlikely that you'd realize anything beyond a 3.5% mpg improvement. That would be at a steady 70-mph. |
