EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Journalist praises 2010 Camaro's "slick" drag coefficient of 0.37 (https://ecomodder.com/forum/showthread.php/journalist-praises-2010-camaros-slick-drag-coefficient-0-a-7741.html)
MetroMPG 04-04-2009 11:29 AM
This is not a joke. (April 2 was too late to be April Fools...)
Jeremy Cato, the chief auto writer for Canada's biggest newspaper, says:
The body is pretty slick, coming in at 0.37 for its drag coefficient.
http://images.theglobeandmail.com/ar...ro02wh3big.jpg
Source: globeandmail.com: globeauto.com An asphalt-melting, tire-smoking blast of fun
Sad, sad, sad - on several levels.
Tango Charlie 04-04-2009 11:33 AM
Well, it LOOKS slick, so it must BE slick, right? :rolleyes:
evolutionmovement 04-04-2009 11:48 AM
Maybe because it actually looks worse than .37?
MetroMPG 04-04-2009 12:08 PM
If he hadn't linked "slick" to "0.37", I'd have no problem with it. Slick is subjective; 0.37 isn't.
Or if he'd qualified it as a relative statement by beginning with, "Compared to a Hummer (or a barn), the body is pretty slick, coming in at 0.37 for its drag coefficient."
GM engineers are so much better than this. They could have optimised details to end up with a less embarrassing Cd - without affecting the overall styling - if they'd wanted to. Maybe the bean counters held them back.
Electric Frenzy 04-04-2009 12:43 PM
This is another (acceptable by me) example of form leading function. They aren't trying to make efficient cars. They are trying to get people to give them money and that classic hotrod styling will do that.
The writer of the article is a dolt though. That's like bragging about the RX8 being good on gas at 17mpg.
p.s. I <3 mazdas and the RX8.
NeilBlanchard 04-04-2009 01:16 PM
Well, it is "slicker" than a Durango! (0.37 vs 0.39) :rolleyes:
winkosmosis 04-04-2009 01:51 PM
How do you figure? They wanted the square nose and notchback body. How would they reduce the drag of that?
My Miata has a shark nose and smooth lines, but the convertible/notchback causes the cD to be 0.38
Drive Stick 04-04-2009 01:51 PM
The front end of the Camaro (grille & headlight area) is like a parachute.
Haha.
& more haha.
Pretty SLICK!
ALS 04-04-2009 02:45 PM
Probably a whole lot better than a 1967-1969 that came in closer to .45 or worse.
SVOboy 04-04-2009 02:47 PM
What that the ugly car I followed at a stop light yesterday? I guess so.
