EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   Jumping in, 92 Civic CX with DX swap. (https://ecomodder.com/forum/showthread.php/jumping-92-civic-cx-dx-swap-16655.html)
caeaves 03-30-2011 03:57 PM
I had been searching for quite sometime for a clean Civic HX or VX to no avail. Most were overpriced, swapped, or otherwise beat to death. I opened my search to the anemic CX as a potential VX or HX engine swap candidate but still nothing out there.
Until last week, when on my day off I decided to check the Raleigh area Craiglist one more time. I had already been denied another HX in Maryland that sold in two days. This beauty popped up and I called the place, told them to hold it, and I would be right there.
I couldn't get there fast enough!!! 104,000 miles, theft recovered CX, with a recent maaco (aka: crappy and oversprayed) paint job. Interior is clean, no tears in the pleather, and nice and black. Just missing a few things like the ash tray and the trim piece around the cd player. I popped the hood and noticed a DX engine inside. A free 30 horsepower upgrade. I'm thinking it has been mated to the stock CX trans which should maintain the good gas mileage because the gearing is dog slow. I will write the trans code down and do more research on it. The tires are matching 09 year as well as the battery. The air intake tube is a CX tube poorly stuck on the larger DX throttle body. Will need to source something better than that. A straight metal tube would be ideal.
Overall, clean and straight.
So far I have removed the lock cylinder and moved the tumblers around to get the key to work in the driver's door. I also added my leftover Integra type R strut bar. Nothing gets rid of rattles and makes a civic feel tighter than that little mod. I've had one on every honda/acura I have owned. Also, aimed the headlights a little better and filled up the tank. At 200 miles at the halfway mark currently. Hoping for 45 mpg but we shall see.
http://i29.photobucket.com/albums/c2..._8301039_n.jpg
http://i29.photobucket.com/albums/c2..._6476746_n.jpg
caeaves 03-30-2011 04:06 PM
First real mod will be security!!
caeaves 03-30-2011 09:09 PM
Just detailed the interior only to find out the floor on the passenger side was soaked and possibly the driver side floor too but not as bad. I think I can hear water swishing about when turning. The rain was intense the past few days. Also leaking from the tail light gaskets as well. Le sigh.
SVOboy 03-30-2011 09:23 PM
Leaks always annoyed me a lot with my CRX. They're all easy to fix though.
Did you already swap the DX engine in?
caeaves 03-30-2011 09:56 PM
It came with it. Still has the CX header and one wire 02.
Creeper 03-31-2011 12:27 PM
Nice little red machine you rarely see a civic with so few miles on it. The CX is a good base line I knew a guy that have an original CX and all he did was lower it and put strut bracing on it and a 5spd stock CX conversion.
caeaves 03-31-2011 12:49 PM
Turns out there is a TSB regarding the leak. I need to remove the fenders and apply additional seam sealer at the base. I'll post the TSB pic later.
I couldn't believe the mileage as it's so easy to swap clusters but the pedals, carpet, seats, and trim still look really good.
bestclimb 03-31-2011 02:42 PM
You should be able to get 50mpg out of that without to much trouble once you get it all in order.
caeaves 04-01-2011 02:21 PM
We shall see.
Update : ordered the rear diffuser/cover from the VX model! I was already ordering tail light gaskets and other miscellaneous clips and covers. What's another 40 bucks?
Canary5_0 04-02-2011 09:50 PM
Welcome!
