Just confirming - warmer air on EFI
From the looks of the posts on warm air intake on an EFI engine (such as my '89 metro)... it does not result in a significant increase in mpgs. Is that correct?
Just wondering if I should disconnect the ducting currently in place from the passenger-side wheel-well to the air-filter housing or not. Based on what I've read, it doesn't look as though this would help me any in my EFI engine. Sound about right? |
I've been looking at this too, and I think the concensus is that you have to try it yourself and see what happens. I think some cars can have hotter air without retarding timing but others retard with a WAI canceling any benefits.
My Neon has a warm air intake stock pulling air from the middle of the engine bay, the scangauge tells me this tends to be 50F higher than ambient on the highway. I was thinking of ducting it so the intake pulls through the rad directly probably making the intake temp 90 or 100F over current temps. I'll have to collect some data on the ignition timing, rpm, TPS, and current temps and then try the switch to hotter air. Ian |
If this is done, we encourage sharing of the results :thumbup: RH77 |
I removed the hose, the adapter on the cleaner housing, and all the ducting from the fender well. I cannot say if this made anything bettor or not because I simply don't notice, but the engine sounds better in my opinion. I found a video about this. Here you go....................... http://www.youtube.com/watch?v=J9GVd4-zMDY |
