Old 01-16-2013, 02:54 PM   #1 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Manual starters to save on battery size and weight
Starting a diesel the old school way!!
Old 01-16-2013, 03:01 PM   #2 (permalink)
...beats walking...
...similarly, how about the first jet turbine engines that used "cartridges" (like BIG shotgun shells) for field starting?
The Following User Says Thank You to gone-ot For This Useful Post:
Cobb (01-16-2013)
Old 01-16-2013, 03:05 PM   #3 (permalink)
My dad had to crank start his first car. Make sure to retard the timing or it will break your arm.
At work he had to work in a hazard environment with a fork lift. They had all diesel powered vehicles with no electric systems. They used penumatic starters and had a tank they filled up twice. Once to start it, then again for use of the horn or a second start before leaving the shop of a day.
Old 01-16-2013, 03:14 PM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
After seeing this i definitely want my VW XL1 with the deck gun option.
The Following User Says Thank You to jakobnev For This Useful Post:
Flakbadger (01-16-2013)
Old 01-16-2013, 05:28 PM   #5 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I remember seeing some old diesel tractors at a tractor show that had a small gas engine on the diesel engine that was used for starting it, no battery needed at all on them.
Old 01-16-2013, 06:13 PM   #6 (permalink)
My old 6 volt VW occasionally got the no start attitude, so I bolted a Tecumseh spool under the generator nut and used a rope to pull start it. Finally found and old tech who told me to wire two solenoids in series to get it to start reliably. I left the spool on and occasionally used the rope. Ignition on, blip the accelerator once for a prime and to set the choke, right foot on the right rear bumper guard and pull the $%^& out of that sucker. Used to set the timing by ear, listen to the points arc while watching the crank pulley move past the mark, with the distributor cap removed as well as the rotor.
regards
Mech
