just saw this on ebay
Looks cool! Thanks for posting it. But it is 25" long, 11" wide, and almost an even inch tall. They would be a bit of a aero drag. Two would be $200 before shipping and then there would be other hardware to buy. But, of course, I'm thinking I want one or two as well. I wonder if they could be mounted on a trunk (where there is already plenty of draggy dead air). I wonder if I could keep people from stealing them?
20W (or 40 if you buy two) is just about right to keep the battery topped off if you don't drive for a while, but you can't really run anything on that sort of power.. even a modest radio will consume more power than that I would think..
Here is a list of how much power accessories draw, post a while ago (and for a Metro):
http://ecomodder.com/forum/showthrea...olts-8908.html What if the alternator were on a switch, as some have suggested on this forum? Under sunny conditions with a car that draws less power in general and none for accessories, put the alternator on a clutch and let the panel maintain. Let the battery recharge while the car sits at work all day. Use the alternator if necessary. Maybe? |
2.5 milimeters |
try these, cheaper by a whole bunch
40W 2PCS 20W mono solar panels | 2X20 Watt Home Solar Panel | 12V Solar Panels $180 with shipping. i have a pair of the 15W panels that i'll be putting on my Jeep's cargo box this summer |
Even if it's not enough to power the whole car, it should reduce the drag on the alternator pulley right? Getting supplemental charging power should help out some...
Gabi, did you end up buying a pair?
