EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   The "Kamm-back" (K-form) (https://ecomodder.com/forum/showthread.php/kamm-back-k-form-28260.html)
aerohead 02-22-2014 01:14 PM
With some of the preliminary images behind us now,it's time to get into the tasty stuff.
This thread will cover the 'K-form' which is commonly referred to as the "Kamm-back",which is a misnomer due to the fact that it was invented by Baron Reinhard von Koenig-Fachsenfeld.
Fachsenfeld's patents were of such great importance to the Third Reich that the Reich's transportation ministry arranged a way to marry his patents to Kamm's FKFS in exchange for laboratory access,allowing this work to gestate under Kamm's educational credentials,of which Fachsenfeld had none.
The following images depict the physical evolution of the K-form as it morphs from a streamline body of revolution,to a half-body,then given 'practical' anatomical, human factors,and geometrical considerations to produce a viable automobile which can navigate the streets and highways of the real world.All images are adapted from Fachsenfeld's book,Aerodynamik des Kraftfahrzeugs (The Aerodynamics of Road Vehicles),self-published in 1951
http://i1271.photobucket.com/albums/.../11x17Scan.jpg
http://i1271.photobucket.com/albums/...85x11Scan1.jpg
http://i1271.photobucket.com/albums/...85x11Scan2.jpg
In the top table you can see the large wake of Pseudo-Jaray aft-bodies(examples:VW Beetle,Chrysler Airflow,Kaiser Henry J,Porsche 911,etc.)which have too steep an incline to support attached flow depicted in the 3rd and 6th images from the top.By 'relaxing' the roof curvature,up to the K-form 'template',the flow re-attaches,the wake is reduced,along with overall drag.
In the bottom two images you see Fachsenfeld's 'extensible' boat tail concept,as Hucho describes it,which Hucho thought we might consider for contemporary streamlining.The tail would be inflated only for out of town highway driving.It's added length gives the added 'elongation' which Hucho insists for really low drag,and reaches into the realm of the 'phantom' tail,in which the deflected,recombining streamlines and boundary layer half-disk create an impenetrable 'surface',with the streamlines following over it as if it were a solid structure.(Dr.Alberto Morelli observed this with his CNR 'banana' car at Pininfarina's wind tunnel in 1976).
The second table illustrates the 'Mirror-Image' ground reflection concept invented by Paul Jaray in 1922 which implicates a vehicles 'effective fineness ratio',one of the most important criteria in road vehicle aerodynamics.
The third table is the plan-view of the K-form as Fachsenfeld tested it at Stuttgart in the mid-1930s.He plays safe,with no more than 21.5-degrees tangent down-slope angle in side elevation,and 18.5-degrees in plan-view.
This plan-view 'template' favors the 2-D ideal symmetrical wing section contour than Mair's boat tail.Many of the lowest drag cars measured utilize this conservative plan-view contour.
As depicted,with optimized leading edge radii,smooth undersides,no cooling systems,side body camber,tumblehome,full tail,and practical windshield,and wheels,this form will produce Cd 0.12 .
I'll continue to add tables as time permits.
Here is the FKFS 'Jaray/pseudo-Jaray wind tunnel model schematic which was tested with the 5-different lenghs
http://i1271.photobucket.com/albums/.../2-289-142.jpg
Here is the K-form (Koenig-Kamm) FKFS wind tunnel model schematic
http://i1271.photobucket.com/albums/.../2-289-141.jpg
Typically,the K-form was superior in drag compared to the J-form until near full-boat-tail lengths at which point the models were identical in architecture.
NOTE: the models have:
*zero leading edge radii
*zero longitudinal edge radii
*zero tumblehome
*zero front/rear elevation vertical body camber
*bellys are smooth
*there are no wheel houses
*no cooling or ventilation passages
*no 'features'
DRAG of J-Form model:
the Cds for this model,from shortest,to longest length are:
0.33
0.28
0.26
0.22
0.21
DRAG of K-Form model
0.25
0.24
0.24
0.22
0.21
The pseudo-Jaray contours come at a high price.
Also,the boat tailing suffers do to the compromised leading edges etc.,as Walter Lay discovered in 1933.If the source sucks,so goes the sink!
0.205
Here is Kamm's lowest drag,and personal car,rated at Cd 0.23,with Diesel engine and overdrive unit
http://i1271.photobucket.com/albums/...ntitled9_6.jpg
http://i1271.photobucket.com/albums/...ead2/scan5.jpg
http://i1271.photobucket.com/albums/...29BampW1-1.jpg
Here is the only surviving K-car,from Landenburg Castle,measured with compromised belly pan at Volkswagen wind tunnel,@ Cd 0.37.
http://i1271.photobucket.com/albums/...3-29BampW3.jpg
Here is a wind tunnel tuft study of one of the K-form models clearly demonstrating attached longitudinal vortices, where the higher pressure side flow is migrating up into and shearing the lower pressure air on top.These 'true' fastbacks are the most sensitive of all body types to upper edge radii and tumblehome effects.On a dusty,leaf-covered,or wet road,you'd be able to clearly see these tornadoes trailing behind the 'car.'
http://i1271.photobucket.com/albums/...3-29BampW2.jpg
Here is an FKFS drag comparison for 'Jaray' sections of varying L/Thickness ratios from Fachsenfeld's book.
http://i1271.photobucket.com/albums/...ntitled3-3.jpg
Here is a FKFS table,also from Fachsenfeld's book,illustrating a 16.6% difference in drag depending upon whether or not tumblehome,and edge radii are present.You can see the schematic representation of attached longitudinal vortices,spawned by the hard edges.
When BamZipPow can soften the back of his T-100/1-wheel boat-tailed trailer,he ought to realize an additional mpg increase.The cherry on top of the whipped cream!
http://i1271.photobucket.com/albums/...ntitled4-3.jpg
Here is Professor Wunibald I.Kamm's last K-Car,a modified DKW (AUDI),front wheel drive notchback sedan,built for the Battelle Institute.If you look through the rear windshield you can see the original notchback architecture hidden underneath the Kamm extension.Fachsenfeld's patented split-fin stabilizers are used,as with Kamm's personal WW-II era car.This photograph is from AUTOMOBILE QUARTERLY,in an article on Kamm by Karl Ludvigsen.
http://i1271.photobucket.com/albums/...ntitled7-2.jpg
redneck 02-22-2014 04:26 PM
Thanks for posting this info. :thumbup:
Question...
I'm not familiar with "tumblehome". Could you elaborate ?
aerohead 02-22-2014 04:35 PM
tumblehome
Question...
Tumblehome describes the amount with which the sides of the greenhouse tilt in towards the center of the car.
A Fed Ex delivery truck would have zero tumblehome,whereas a Corvette Stingray would have quite a bit.
Here's my CRX and it's inward-leaning greenhouse
http://i1271.photobucket.com/albums/...d2/Scan1-3.jpg
spacemanspif 02-22-2014 04:48 PM
Could you explain what is going on in the last pic of the different car designs? I understand the inflatable tail above it, but am lost when it comes to that contraption on the back of the last one, and why it doesn't have an accompanying pic next to it or airflow lines. It can't possibly have 0 drag at the rear, can it?
aerohead 02-22-2014 05:02 PM
last pic
The last picture is a schematic diagram of the boat tail envelope deflated and storing into,or against the back of the car.
The flow lines are depicted for it's 'deployed' configuration above,and for it's 'stowed' configuration 3rd from the bottom.
The 3rd from bottom and last car would be about Cd 0.25.
The 2nd from bottom would be lower.
freebeard 02-23-2014 03:02 PM
Here's a sketch I did in the 1980s. The retractable wheel and non-retractable exhaust weren't completely thought out.
http://ecomodder.com/forum/member-fr...nd-inflate.jpg
This was my thinking in the 90s: find the point of separation and cut off everything aft of that.
http://ecomodder.com/forum/member-fr...re5624-vw1.jpg
Here's my thinking today: six blisters on the aeroform.
http://ecomodder.com/forum/member-fr...-aero-bug2.png
gone-ot 02-23-2014 03:53 PM
Summary: Kamm-back is about 3-dimensionally minimizing the "volume" of the virtual truncated (vortex?) AIR cone that's drug along behind the vehicle.
aerohead 02-26-2014 11:46 AM
six blisters
from Lay's research (a future post) we might slide on the windshield/cowl area (he got same drag with ideal,or 'conventional' windshield).The sides and tail are key,so rest of blisters would do a nice cleanup.
Ecky 02-26-2014 01:41 PM
Has there been any talk of production of inflatable boat tails for existing vehicles?
freebeard 02-26-2014 03:07 PM
246 people have looked at my Beetle Aerodynamics thread. Were you one?
http://ecomodder.com/forum/member-fr...0-100-0632.jpg
This follows Breers more than the Template.
http://i.imgur.com/kwBkx.jpg
