Old 03-03-2009, 08:24 AM   #1 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Nissan drive by wire throttle
Does anyone know how the drive by wire throttle works on a Nissan Versa? Is it a voltage based throttle? Does the gas pedal act as a potentiometer?
Could I use a switch to bypass the pedal and use a potentiometer to give a constant throttle setting?
Nissan Versa Aeromods
Old 03-03-2009, 09:10 AM   #2 (permalink)
skyl4rk's Avatar
OK, after a bit of research, I am looking for a way to bypass the accelerator pedal position sensor.
It appears to be a potentiometer.
This pdf file was helpful.
http://www.autoshop101.com/forms/h33.pdf
Old 11-06-2009, 12:05 PM   #3 (permalink)
V - '10 Nissan Versa 1.6 Sedan
90 day: 33.04 mpg (US)
Very Interested
I too have a Versa 1.6, and I'm dying to get some kind of alternate throttle control. Be it cruise control, a hand operated POT, maybe even something rigged to pull or push the pedal other than my foot. Have you made any progress?
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
DIY - Wire Tuck SVOboy DIY / How-to 4 01-25-2008 02:14 AM
