EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Lamellar self-blocking grille (https://ecomodder.com/forum/showthread.php/lamellar-self-blocking-grille-7838.html)
aerohead 04-11-2009 02:09 PM
1 Attachment(s)
This is my attempt to get an image up for lunarhighway for the self-blocking grille.If it works,it will be a photo of the article from POPULAR SCIENCE which includes an image of the high-tech grille.
http://ecomodder.com/forum/attachmen...0&d=1239473349
cfg83 04-11-2009 02:34 PM
aerohead -
I got it. It's a very clean image. Thanks!
CarloSW2
lunarhighway 04-11-2009 02:49 PM
thanks a lot! ever since this idea came up i've been looking out for hidden examples of this, and i've seen quite a lot of grill designs wich suspiciously resemble this design...
Frank Lee 04-11-2009 04:40 PM
Thanks for posting!
I KNEW I'd read about Ford's grille and seen an illustration, but didn't have it in my archives and didn't find anything Googling for it.
vtec-e 04-11-2009 06:22 PM
The suzuki sx4 has a similar concept i think: Suzuki Auto / SX4 Crossover
ollie
cfg83 04-11-2009 07:16 PM
Hello -
For our purposes, does the scale have to remain the same? Can we have different scales as long as we maintain the same proportions of angle and shape relative to the oncoming air?
Can the shape be simplified to being just a curve? That would make manufacture easy. Just cut up some tubing and install at an angle. I am guessing it *does* need the "fatter bottom", because it looks like an airfoil.
CarloSW2
cfg83 04-11-2009 07:18 PM
vtec-e -
ollie
I believe that. It's a joint venture with Fiat, so I wouldn't be surprised if they integrated that kind of aero-trick.
CarloSW2
TestDrive 04-11-2009 08:36 PM
I wonder if the under/concave side of each foil isn't shaped that way to conserve material rather than being an aero driven design element?
Frank Lee 04-11-2009 11:44 PM
Ease of manufacture for sure has a lot to do with the way it is.
winkosmosis 04-12-2009 01:19 AM
Why shape it otherwise?
