Large naturally aspirated engines are more efficient than small turbos
CR testers are among the strongest of arguments for the link between humans and apes. They consistently get well below EPA figures in their "economy tests", which no doubt consists of mashing the skinny and fat pedals in an alternating fashion until they arrive at their destination. I could not get the horrible economy figures they come up with if I tried.
While I appreciate much of the info CR provides, fuel economy is one that I completely dismiss. Here is the Cruze figures from "Drivers Like You" on fueleconomy.gov A completely different conclusion can be drawn from this data, and suggests that CR drivers are troglodytes. |
How many of those with turbos are also a bump up in trim level, often leading to the entire vehicle being heavier with wider tires, the 0-60 times of the turbo models also tend to be faster, so as I understand it, it's still possible to get better mileage with a smaller turbo engine, but the rest of the car has to be designed to work with it.
The new small displacement turbo engines are designed to improve the manufacturer's CAFE numbers, not real world fuel economy. |
Apparently they have no idea how to do real testing. :rolleyes:
The data they presented showed hair splitting mpg differences ( 1 or 2 mpg ) while giving no information about the vehicle that the engine was in. Details such as vehicle mass, transmission, drag coefficient, or frontal area would all play a major part in such a test, but they simply lumped all vehicles that had a range of engine displacements into the same category. |
A Turbo gasoline engine need 20% fuel to make the same horsepower as a N/A motor.
But on the other hand a turbo diesel gets better fuel milage with a turbo. I have done the N/A to turbo diesel thing and picked up 2mpg on my diesel suburban. |
Having seen too many CR reports that conflict with my experience and/or readings, I dismiss ALL OF THEIR CONTENT.
^^ this.
So the Altima did best at 31 MPG, pretty close to fuely's figures for the 30 4 cyls of 31 reported (1 V6) and 0-60 in 8.2 seconds. The wife averaged clsoe to 29 in her Rogue, same engine, I think they did some more tweaks to the CVT.
regards Mech |
