Laser spark plugs?
Hi EcoMen,
Do any of you know if laser spark plugs are available to purchase from anyone? Unfortunately, I can't link the article I read this in, but apparently going from standard to laser ignition yields like a 20% improvement in bsfc. Absolutely crazy. I run Iridiums already on my G10, but you know, it'd be nice if I didn't have to worry about any spark plug service interval period. Regards, Jordan |
I had never heard of laser spark plugs before. A quick search only reveals Laser™ trademark brand name iridium spark plugs from NGK. What am I missing?
Search "laser ignition advantages" and you'll see what I'm talking about. Damn scientists... touting so many great advantages on a product not sold in stores!
Well yes... that's why I was asking you guys here. If it's available outside labs at all, even if it takes a heck ton of fabrication work, someone on this forum will have done it if it improves MPG that much. Also, yes thank you Freebeard - I can't post links because I'm new, apparently.
I guess laser spark plugs not becoming a thing is a result of the EV madness. Even if the ICE gets a brighter future, I wouldn't really hold my breath for laser ignition.
IMO
I think the manufactures need to do a totally new design on the ICE. Something that does not resemble a 4-cycle engine at all. "Too much thermal and mechanical loss". F1 has pretty much tap out on how much energy you can get from a 4-cycle pistons/rod with tulip valve design. Even the rotor engine has way too much surface area. Now some of the newer ones have made some improvement. Also, I think combustion needs a redesign also. Nano fuel technology might be the answer. Today's vehicle emission systems are very crude. Closed loop is a joke in itself. With today's technology we should have been able to run a cat less system and obtain even cleaner emissions. OK I'm done with my rant :) |
