EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   This lawnmower never needs an oil change (https://ecomodder.com/forum/showthread.php/lawnmower-never-needs-oil-change-34153.html)
ME_Andy 08-06-2016 03:48 PM
(from my blog, PVcharts.com)
Briggs & Stratton has come out with a cool new lawn mower that never needs oil changes! According to their website, the secret is a better air filter and a cooler-running engine, which extends oil life. The owner just needs to check and top off the oil occassionally.
http://www.pvcharts.com/Eblog/wp-con...ne-300x300.jpg
The other feature of this system which isn’t mentioned in the PR, I’m sure, is that lawnmower engines tend to burn a fair amount of oil. Thus they will frequently need topping off, which replenishes the oil’s additive package. The company would rather not focus on oil burning as a feature, but I would bet it is crucial.
As electric vehicles become much cheaper, conventional gas engines will need to exploit all kinds of technology to stay competitive. And let’s face it, oil changes are one of the worst aspects of a gas burner. So, my humble prediction is that automakers will advertise longer and longer oil change intervals. We may even see some creative systems where oil is no longer drained, ever, but partially siphoned out and topped off to replenish additives.
There is precedence for this “replenishment” technique already. A couple links from people who NEVER changed their oil follow– they just topped off as old oil was slowly burned off. If you’re “lucky” enough to have a car which burns oil (mine doesn’t), you could probably pull this off. My father’s 1996 diesel F-250 went about 50,000 without an oil change and was still ticking fine at 180,000 miles.
There are at least two synthetic oils on the market (Amsoil Signature and Mobil1 Extended Performance) which guarantee suitability for 15,000 mile oil changes. So, it isn’t a huge mental leap to imagine an oil-change-free future. I would never change mine at less than 5,000 miles. If you do, you’re wasting cash.
122,000 miles without an oil change – Nissan truck
38,000 miles without an oil change – VW Jetta
250,000 miles – ’72 Buick Rivera – discusses Car Talk and a government study as well
13,000 miles – Honda Insight
elhigh 08-06-2016 08:26 PM
I have a Subaru that never needs an oil change either - just add a quart every thousand miles, change the filter every three. The old oil leaves via assorted small convenient exits.
ME_Andy 08-06-2016 08:42 PM
Yep, that's what I'm talking about. Now somebody just needs to design a system that constantly siphons off old oil (burn it or store it) and feeds in new oil from a reservoir.
nemo 08-06-2016 09:38 PM
Sounds like a 2 stroke to me.
V6MustangFTW 08-06-2016 10:36 PM
My mom's old Aztek never needed an oil change either...it all got burnt before I could get around to it :p
oil pan 4 08-06-2016 11:12 PM
That has been around since at least the 1950s on diesel engines. Detroit diesel used a needle valve to meter engine oil into the fuel to burn it off. Then the operator would add more.
By the 1960s they had auto oil fillers installed on engines.
oil pan 4 08-06-2016 11:14 PM
I would still change the oil.
It's likely only about 3/4 of a quart.
MobilOne 08-07-2016 12:08 AM
Oil is cheap. Engines and vehicles are expensive.
ME_Andy 08-07-2016 12:31 AM
Cool. Now integrate it with software so the car knows how much to burn off (or store) and give the driver an indicator to add more on the dashboard. It sounds like any patents on this stuff should have expired by now.
jamesqf 08-07-2016 01:02 AM
Originally Posted by ME_Andy (Post 520064)
Briggs & Stratton has come out with a cool new lawn mower that never needs oil changes...
This is news? I've had one for a good many years. Not only does it not need oil changes, I never have to put gas in it, either. Or pull on a rope dozens of times, hoping that this time it'll start. Or listen to the noise of an inadequately muffled IC engine. No, I can just flip the switch and go. Plug it in to the charger occasionally, sharpen the blade once a year, and that's it.
