LCD Idea
LCD Keypad Shield for Arduino [] - £11.00 : nuelectronics.com, Arduino Freeduino projects
That one is basically stackable onto the Diecimila board (what I have). Thing is, the buttons work a little different (voltage divider). Also, it uses lcd data pins 0-3...it seems kinda close. More or less a code change maybe? I thought I would throw that out there since the easier it is to assemble, the more likely more people will be involved in the project. More info: http://www.nuelectronics.com/estore/?p=6 |
It still needs extra circuitry to make an mpguino out of it. I think we will be happier once we have a kit with a custom PCB, I (and a few others) are working on it.
I think arduino would benefit from a "standard computing platform", that has a "display" and "keyboard", just like this kit, or like a mpguino without the vehicle interface circuit.
It worked for the PC :) Unfortunately it is going in several directions at once and nerdy decisions have to be made by all ;) re: kit, it'll be a few weeks at least. I need to buckle down on it. |
