Lead-Acid Batteries Voltage Sag Formulas
Hi everyone, There seems to be a number of people responding to the Electric Car threads, so I wondered if anyone knows of some formulas that can be used to determine - ahead of time - how much the voltage will sag on a Lead Acid Battery, under some specific load or varying load?
While I have a PakTrakr - and a Woodward Enhanced PakTrakr Display - with Data Logging - I have a lot of empirical data, but no formula - maybe someone can look at the data and come up with a formula? Electricfly - MyElectricfly.com and NoGas96volts PakTrakr Multi Battery Monitor Battery Pack Monitor and Thanks for you help, ahead of time! Robert |
Where are the data points? I could try to come up with a formula for voltage drop. It would at least be a function of current and temperature, and perhaps current and temperature and state of charge.
Data Points
I could make them posted in my electricfly site for access if you like? Robert |
ya! Post those buggers!
One Weeks Summar Log of the Loads with Electricfly
2 Attachment(s)
It is just a set of key highlights, but fishing though a table in Excel with 32,000 lines is no fun, trust me! True - actually having a Packtracker on a battery, with the woodward display - logging the data, while doing a load test on a Lab Bench would be even more definative, and controllable, but here are some high points, and you can be sure the max current points and minimum voltage points are within a few seconds of each other for the most part. By the way - Have you checked out EV Fest 2011 yet? Robert |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
