EcoModder.com
-   -   leds light problem (https://ecomodder.com/forum/showthread.php/leds-light-problem-21975.html)
echo-francis 05-19-2012 09:21 AM
leds light problem
last week i order some leds light at superbrightleds.com all is good but the tail/stop light is not working but at the place of the rear flasher it work:confused::confused: what type of tail/stop light i have to order?
2000mc 05-19-2012 10:10 AM
If the turn signal and brake use the same filiment, Have you tried reinstalling a standard bulb and rechecking? I'm wondering if the problem just wasn't noticed previously
2000mc 05-19-2012 10:37 AM
does it have a separate turn signal bulb?, tried spinning it 180? (its a diode)
California98Civic 05-19-2012 11:42 AM
On your stock bulbs the part numbers should be printed. Search online for the right substitutions in LED for that number. I use superbrightleds.com too and have had no problems. Try turning the bulb 180 degrees like 2000mc suggests too. I did that with one bulb and it worked, IIRC.
echo-francis 05-20-2012 04:28 PM
turning it 180 degrees did not work
when i turn on the light it dont work but when i press the break pedal it work, i think it have 1 intensity and my stock light have 2
2000mc 05-20-2012 05:06 PM
know what the number on your new led light is?
California98Civic 05-20-2012 07:40 PM
That seems correct.
eco_generator 05-29-2012 04:44 PM
You want a 7443 bulb, not a 7440 if that is what you have. If you have a 7443, then its defective.
The car bulb finder on the website should get you the correct product. They don't even list a 7440 option for the tail lights of your car.
echo-francis 05-29-2012 04:53 PM
they send me the wrong led thats the problem
