Old 05-19-2012, 09:21 AM   #1 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
leds light problem
last week i order some leds light at superbrightleds.com all is good but the tail/stop light is not working but at the place of the rear flasher it work what type of tail/stop light i have to order?
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 05-19-2012, 10:10 AM   #2 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
If the turn signal and brake use the same filiment, Have you tried reinstalling a standard bulb and rechecking? I'm wondering if the problem just wasn't noticed previously
Old 05-19-2012, 10:37 AM   #3 (permalink)
Team Saturn
does it have a separate turn signal bulb?, tried spinning it 180? (its a diode)
Old 05-19-2012, 11:42 AM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
On your stock bulbs the part numbers should be printed. Search online for the right substitutions in LED for that number. I use superbrightleds.com too and have had no problems. Try turning the bulb 180 degrees like 2000mc suggests too. I did that with one bulb and it worked, IIRC.
Old 05-20-2012, 04:28 PM   #5 (permalink)
40-60-40 MPH P&G
turning it 180 degrees did not work
when i turn on the light it dont work but when i press the break pedal it work, i think it have 1 intensity and my stock light have 2
MPG=1 TIME=0
Old 05-20-2012, 05:06 PM   #6 (permalink)
Team Saturn
know what the number on your new led light is?
Old 05-20-2012, 07:40 PM   #7 (permalink)
Cyborg ECU
That seems correct.
Old 05-29-2012, 04:44 PM   #8 (permalink)
AeroGuy
eco_generator's Avatar
Outback 14 - '14 Subaru Outback Limited
90 day: 23.1 mpg (US)
You want a 7443 bulb, not a 7440 if that is what you have. If you have a 7443, then its defective.
The car bulb finder on the website should get you the correct product. They don't even list a 7440 option for the tail lights of your car.
Old 05-29-2012, 04:53 PM   #9 (permalink)
40-60-40 MPH P&G
they send me the wrong led thats the problem
MPG=1 TIME=0
