Liquid cooled/warmed oil filter mount?
I saw a post on a Miata site of someone puting this mount off an Alfa 164 on his Miata. It has engine coolant running through the oil filter mount. Anyone use this mod?
A lot of the high mileage spec cars do like the Civic VX, HX, and the Honda Insight. It doesn't seem to be a popular add on item though.
You could possibly use something like this from a Subaru Forester and can be had quite cheaply from a junk yard. As long as the thread pitch and size is the same size, it should work for a number of applications.
It simply screws in place between the oil filter and the block. https://image.ibb.co/hgfaux/20180403_184914.jpg |
