little oven element
I was looking over the little convection oven I have and fond four elements. 2 are used to go to 450F then four...
I ponder making a heater, all in one for the car. I have yet to figure the fairy tale with 12volts. it can be alot bigger than what we are constipated with. I am thinking power invertor, little element, about 300watts, I mean tiny element, it is a bout .25 diameter by less than 12X10 shaped in a "u". A metal lined whatever box.. anybody done this? I also ponder a .25 amp computer fan, to mimick a convection, or flow to start then let it get sucked into car recycle vent (I have mine 50/50 outside/in permanent) I was hoping to do this before the melting glaciers killed me with hypothermia in a heated room..:confused: |
How about one of the pre-made dealies for that? Anything connected to your cig. lighter socket is going to be limited to under 150 watts because that's all the socket can supply - but there are some direct wire ones good for almost as much as a household space heater.
12v heater - Google Product Search |
