EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Look! Up in the sky! (https://ecomodder.com/forum/showthread.php/look-up-sky-26349.html)
jamesqf 07-08-2013 12:26 PM
It's a hybrid airplane: Once a Joke, Battery-Powered Airplanes Are Nearing Reality | MIT Technology Review
Last month Siemens and EADS demonstrated a new gas-electric vehicle capable of carrying two people and their luggage 900 kilometers—roughly the distance from New York to Detroit—between refuels and recharges. The prototype was not a car, but a small two-seater airplane.
The hybrid plane is similar to the Chevrolet Volt in that it relies on an electric motor and uses a gas engine as backup. The airplane matches the performance of some private airplanes already on the market, but it has two distinct advantages: it’s remarkably quiet, and uses about 25 percent less fuel.
NachtRitter 07-08-2013 12:38 PM
Very cool!
gone-ot 07-08-2013 01:04 PM
Airport PA says "...ALL FLIGHTS HAVE BEEN CANCELLED DUE TO CLOUDY WEATHER..."
Xist 07-08-2013 01:27 PM
Did it say that it was solar?
Would it take off under battery or fuel? Quiet airports would be revolutionary!
NeilBlanchard 07-08-2013 01:43 PM
The article implies, but does not state explicitly if this is a serial hybrid? If so, what details do we know about the ICE portion of the system? What is the capacity of the battery pack, and what is the output of the generator?
jamesqf 07-08-2013 03:43 PM
All I know about it is in the article. Some of the links are interesting, too.
I do notice one mistake in the article, at the end, about making it possible to eliminate lead from avgas. The real problem is the number of existing aircraft that under FAA regulations can't have their engines modified or replaced with a different engine without going to the great expense of obtaining an STC.
gone-ot 07-08-2013 03:55 PM
STC = Supplemental Type Certificate from FAA.
NachtRitter 07-08-2013 04:11 PM
Are new private aircraft built with ICEs that can handle lead-free fuel? If so, I'd be surprised that the airports don't offer both fuel types. Admittedly, I'm not all that knowledgeable about private aircraft...
euromodder 07-08-2013 06:09 PM
Let's stay down to earth, it's a motorized glider design ...
Those don't need much of an engine anyway.
jamesqf 07-08-2013 06:44 PM
Generally, yes. Or you can get an STC for many of the the more common models: my Piper Cherokee has one, and runs just fine on premium from the gas station.
Mainly it's a supply & demand thing. Aviation gasoline is a pretty small market, so few refiners produce it, and most airports only sell 100LL (100 octane, low lead). Some of the older warbirds take up to 115/145 octane.
