Old 10-26-2008, 10:35 PM   #1 (permalink)
BKO
bottonavy's Avatar
'06 Toy - '06 Toyota Tundra SR5 4WD Extended cab
90 day: 17.51 mpg (US)
'10 Corolla - '10 Toyota Corrola LE
90 day: 36.38 mpg (US)
Horn upgrade suggestions
I'm looking to upgrade to a louder horn from my stock wimpy sounding horn. What are some horns that are really loud. I prefer electric over air due to the weight factor. I have heard of Stebel horns. They are usually 139db range. Are there louder ones out there? Thanks in advance
Brian
Old 10-27-2008, 12:06 AM   #2 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
i think 139 is plenty loud, i think they say that at 140 you can experience immediate and permanent hearing loss. wouldn't surprise me if thats why its 139 and not higher.
Old 10-27-2008, 12:45 AM   #3 (permalink)
Danger Ranger - '01 Ford Ranger Edge 4x4
90 day: 14.52 mpg (US)
Moms car - '05 Ford Freestyle Limited
90 day: 21.92 mpg (US)
Mistress - '10 Harley-Davidson 883 Sportster 883 Iron
90 day: 42.53 mpg (US)
Send a message via AIM to meemooer
it also helps at where it is located. Currently i have one of the 3 trumpet"big rig" horns, it's load, but not when the hood is closed. You can hear it on the highway, or make co-workers crap themselves when they go under your hood at work
Randy
Old 10-27-2008, 08:37 AM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I had this Dixie Horn for about 5 years and it finally quit working. The air compressor would run, but not sequence properly and 2 of the horns would no longer make any sounds. I used this horn in my 1993 Chevy van and my 1971 Dodge Demon. As soon as I bought my Metro, I installed it, but removed it when I discovered it was broke.
I am not one to let a $60.00 horn go in the trashcan, so I modified the horn so it would at least be use-able. I removed the top cover and removed the rotation diaphragm and springs and then used silicone to seal the horn and also block off all of the ports but one................
I then let the silicone dry and used the longest (loudest) horn and hooked it to the single port. I now have a very loud single tone air horn in my Metro to replace the cheezy horn it has. It sounds like a big rig horn.............
GeoMetroforum.com - got mpg?
Old 10-27-2008, 08:39 AM   #5 (permalink)
I got a junk yard horn from a Buick Electra to put on my old Datsun. It sure turned some heads.
Old 10-27-2008, 01:45 PM   #6 (permalink)
The higher sound level horns are also generally higher pitched.
So while being loud,
they don't get much attention.
There are a set of horns at the auto store from WOLO (and others)
that are 125 dB.
One horn is high pitch, the other low.
Together they have that great old Buick sound.
Mine are wired so the high pitch 'beeps' normally,
and they both go on if the brakes are applied.
This gives the big sound when needed,
but the friendlier high pitch when you want to just beep Hi.
I've done this on my motorcycles and in my car.
works great and that dual tone gets noticed.
Tech note,
older people don't hear the hi pitch very well,
it takes twice the power to raise the level 3 dB (ie 125 to 128)
but it takes 10 dB more to sound louder to the ear.
Old 10-27-2008, 07:45 PM   #7 (permalink)
Hi,
The Fiamm horns are pretty darn loud, IME.
Old 10-27-2008, 08:23 PM   #8 (permalink)
Harbor Freight sells some pretty inexpensive air horns. The horns are made out of PVC. I think they are rated at about 135db. I have one on my 1988 Escort, because the factory horns weren't very loud and sometimes the horn button in the steering wheel didn't work so I reworked it with a $25. air horn.
Old 10-28-2008, 12:32 AM   #9 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
I took the horns from an older Cadillac.
Two electric horns mounted on the radiator support behind the front bumper.
The original wiring wouldn't carry enough current to operate them both at the same time so I wired a relay from the old wiring.
Horn wiring to operate relay.
Relay directs battery power to the horns.
Work good, last long time G.I.
Schultz
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 10-28-2008, 03:01 AM   #10 (permalink)
DMC - '99 Honda Civic DX
I met a dude that had a train horn on his civic. It turned heads half a mile from him.
vac-n-tach... diy custom pod suggestions? lyd Instrumentation 18 02-10-2009 02:12 PM
Suggestions on how I can improve my MPG on my commute?? regor Hypermiling / EcoDriver's Ed 4 06-09-2008 02:03 AM
Local commute suggestions thebrad General Efficiency Discussion 51 05-20-2008 09:49 AM
Commute Route - Suggestions Nerys Hypermiling / EcoDriver's Ed 12 05-08-2008 04:59 PM
