Looking for a "Lite Linux"
I take in old computers, take the Windows OS, replace with a Linux-based program and run the Stanford University Gene Folding Project (Distributed Computing). The PCs don't have to be fast, just willing to grind away at 100% processor capacity until they wear out. So far, I'm up to 9 computers...
#9 is a challenge. AMD K6 @ 300 MHZ with 64 MB RAM and a ~640 MB HDD (desktop). Request: No live CD. I've tried a few without success -- they don't meld with something in the system Ideas? RH77 |
FWIW, I had a 350mhz K6-2 that would only boot with an older Gentoo livecd. I also read that specific distro install cds from Ubuntu/etc... Could work, but I never tried 'em to see if they worked. Naturally, after installing/compiling everything, which took quite a bit of time, it ran fine.
Try "Damn Small Linux"
openbsd? :D
actually I used to use trustix for all my servers I think it was around 300mb for a full install. For a setup dedicated to running a single program like that, how about setting up a pxe boot environment that uses something like dsl or puppylinux as the boot image and is tuned for only running that single task? That way you don't need any drives at all in the computers, just cpu ram and a network card. Less power wasted that way spinning an otherwise useless drive. I pretty much have went the low power route at home now so I haven't used an actual x86 based server for a year or two so my knowledge of current distros might be out of date. |
The HDD had a corrupt Win98 OS on it before I started formatting and partitioning for whichever Linux variant was tried. Puppy was too much for it and it barely budged after about an hour after making a request (not enough memory). Vector Linux -- can't download a decent version (bad checksums). I may try DSL or trustix. Honestly, my noobness currently requires a GUI, which likely steals from the total power available. On my newer machines, I've used OpenSuse, and a variety of Fedora releases with ease. One is a backup server for 2 laptops (primary household workstations). So far, old, doorstop PCs have been saved from the recylcler. RH77 |
how about this? http://reilly.homeip.net/folding/diskless.html
on closer look that is actually a pretty clean linux install. If you have a linksys wrt54g router you can also put the openwrt firmware on it and configure the dhcp settings so you really won't need a windows machine running tftpd32 or any other client.
Could just slap a computer together without any drives set the bios to pxe network boot and it is up and running in like 30 seconds :) and crawling the directory of that howto gives you this url: http://reilly.homeip.net/folding/ and there are some interesting clients there if you want to keep the hd in each system even |
Back when I was a student and had really nothing productive to do I did a stage I Gentoo install on exactly this same processor. It took 2 days to compile everything, but the distro ran quite fast for a k6-2 300.
