Low budget aero hubcaps (magnet attachment)
2 Attachment(s)
I bought four steel pizza pans from my local dollar store, and superglued neodymium magnets to them in a location that centers the cap on my wheels.
I first drilled and then reamed a hole to fit the valve stem through. The wheel rims I have have a central ridge with a diameter of about 7 inches that projects flush with the edge of the rim. The pizza pans have a nice stepped rim that stiffens them and gets the rim 'down' below the airflow. Locating the magnets is easy. Stick them to the ridge on the rim, put a dollop of glue on each magnet, then put the pan over the whole works. You'll have a couple of seconds to center the rim before the glue grabs. You can also measure a circle about the right diameter and glue the magnets to the pan before attaching it. I did both, to see what would work better, and saw no real difference. Now to see if they will hold on at highway speeds and over bumps... :eek: This first step toward aero improvement was inspired by someone's post here about using pizza pans for hubcaps. I didn't have any stock spring-friction fit caps to use, so magnets came to mind. These neodymium magnets are very strong, and I'll find out if they're strong enough. Total cost- $4.00 US (plus 0.32 tax) and two dead hard drives scavenged for magnets. Total time= about 15 minutes each. |
Post of the day! :thumbup:
My pizza pan hubcaps are held on by 3 screws going into drilled and tapped holes in the wheel. I'd be a bit worried by not having a direct physical connection between the hubcap and the wheel, then hitting a bump with that 60psi tire and the jolt sending that hubcap spinning off into traffic.
Hmm- I hadn't really thought of how they might affect other drivers if they flew off. I may have to come up with something better... (Although my tires are at 40psi, and don't thump that hard.)
jim-frank -
I still like the idea, but it may not work on cars at highway speeds. CarloSW2 |
Looks like hard drive magnets! Clever. I hope it stays on for you, and if it does, I hope next time you go to remove them, the glue is stronger than the magnets. :)
He kept going and so did I :thumbup: |
Has anyone done a before and after MPG gain for Aero Hubcaps of any kind? Is it really a lot?
It's very small (probably too small to notice through tank-to-tank monitoring).
It also falls into the "it depends" (TM) category: Depends on how aerodynamically dirty the previous wheel style was to begin with; also the airflow characteristics past the wheel wells of the vehicle in question. |
